Failed Safety Inspection leaking power steering rack
Results 1 to 10 of 10
Thread: Failed Safety Inspection leaking power steering rack
    May 2009
    Virginia
    487
    236
    I took my vehicle in to get state inspected and it failed for a leaking power steering rack.
    I have never replaced a power steering rack, but I would anticipate a failure to be clearly visible.
    All I see is a bit of grime around one part of the rack.
    Do you have any thoughts as to whether or not this would actually be leaking?
    If it is, I don't think that it is enough to substantiate grounds of a favor unless they were feeling money hungry.
    Please see below. PS Sorry battery not charged for high resolution camera. This is the best that I could do.
    Thanks!
    Jan 2009
    Ohio
    595
    Bing it back and say it is just oil spilled on it. Is it dripping out of the rack?
    01 Dodge Grand Caravan (Sport) 3.3
    New tranny at 99,650 miles
    Currently 123,000 miles
    May 2009
    Virginia
    487
    236
    Quote Originally Posted by Kscha41 View Post
    I don't see it leaking...that one part looks dirty/grimy etc.
    Do you see it leaking?
    Nov 2008
    westland, mi
    547
    are you losing fluid? I'd check that first, if not so bad clean it up and get it inspected again.
    99 plymouth grand voyager se, 3.3 engine, 185 000 mi. recently replaced engine, repaired strut towers, and other odd ball repairs and now just finished rebuilding the tranny, should be good for a while.
    Jul 2005
    NJ
    1,571
    6
    Doesn't look like it leaks through the seals, in any case. Maybe one of the flare nuts connecting the lines can be tightened, but it looks normal to me.
    Apr 2007
    Minnesota
    4,206
    What state are you in?
    If it isn't puddling oil on the ground, I would say it is acceptable.
    It might be time to find a different shop. This one sounds like they are pulling a fast one.
    May 2009
    Virginia
    487
    236
    Hello all, I am in Virginia.
    Thanks for your thoughts.
    I cleaned it up as much as I could see.
    The reservoir was full to.
    Sounds like a rip off.
    I will go elsewhere.
    Oct 2003
    Mt. Sinai N.Y.
    268
    15
    Quote Originally Posted by 4_cars View Post
    I would think as long as the fluid leak was not in a place where it could start a fire it should pass. Click on the safety inspection link on this site. It only says a leak in the brake system is cause for failure.
    http://www.vsp.state.va.us/Safety.shtm
    Apr 2007
    Minnesota
    4,206
    Do you have a DOD sticker or anything else on the windshield that spells "Sucker" or something?
    Apr 2007
    Minnesota
    4,206
    I will say that I don't miss those days when I was in the Navy and had to have one of those to get on base regardless of having out of state plates.
  1. Leaking Steering Rack
    By Hankster in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 07-11-2010, 09:05 PM
  2. Leaking Steering Rack? Two spots under front end
    By markho in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 03-02-2010, 03:50 PM
  3. Leaking Power steering, SOMETHING
    By aKids2003_DGC in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-05-2010, 02:24 PM
  4. Failed Safety Inspection leaking brake cylinder
    By 4_cars in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-29-2009, 02:49 AM
  5. Leaking steering rack
    By My_van_dont_work in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-16-2008, 07:53 AM
