Engine Light On ( Code errors P0455 / P0456 ) 2008 Town and Country
Results 1 to 5 of 5
Thread: Engine Light On ( Code errors P0455 / P0456 ) 2008 Town and Country
    May 2007
    220
    After getting the engine light on I do the test ( insert key, turn on, turn off, turn on, turn off, turn on ) and get this error codes:
    P0455 / P0456
    Can I drive the minivan without any problem.
    Do I need to go urgently to the dealer so they fix this problem.
    Reading here I found that this problem is related to some hoses broken.
    Also the error codes from here ( http://www.allpar.com/fix/computer-codes.html ) say: Evaporative Emission (EVAP) System Leak Detected
    Also on other web page they say this:
    P0455 AND P0456 are all evaporative leak monitor test failures (medium and large leaks).
    Jan 2008
    Nova Scotia, Canada
    16,539
    Check your gas cap for tightness / several clicks. That problem would be covered by your emissions warranty, I would think.
    If remedied, disconnect the negative battery terminal for a few minutes to clear the code.
    May 2007
    220
    Also a strange burning smell have appear days ago, I think it is related.
    I will go to the dealer as soon as possible.
    May 2007
    220
    Jeepman the light engine now is off but I still get the error codes.
    The only way to clear the error codes is disconnecting the negative battery terminal.
    Or if I wait the error codes will be cleared automatically.
    At the time the engine code goes on the minivan smells strange.
    Do you think I still need to go to the dealer to check the minivan.
    How perfect is the minivan check engine light system is, can I trust it?
    May 2009
    157
    bring to dealer if under warranty...It could be something as simple as the gas cap...or a hard to detect filler tube fuel blocker clamp missalligned...something simple usually...or could be a vendor issue with a pinhole in a hose above fuel ake...who knows there are a lot of scenerios with this issue...have them figure it out...AND KEEP TRACK of it...because it could come back multiple time for this pain issue unfortunately...It could be a hard issue to pinpoint or a simple one....
  1. 2005 overheating town and country with check engine light
    By tmr91 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 06-10-2010, 10:24 PM
  2. 2003 Town and Country - Rough shift into first (P0456?)
    By serialportme in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 08-26-2009, 10:45 PM
  3. Black Box in your New Town and Country 2008
    By lucke1 in forum 5th. Generation Chrysler Minivans: 2008-2016
    Last Post: 06-14-2009, 03:55 PM
  4. Failed emissions with errors P0442 and P0455.
    By tremendocojones in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 04-02-2009, 06:38 AM
  5. P0455 evap leak large engine light
    By duganfry in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-29-2008, 08:41 PM
