Front Wheel Bearing Torque Spec?
Results 1 to 8 of 8
Thread: Front Wheel Bearing Torque Spec?
    Jul 2004
    3
    Anyone know what the torue spec is for the 32mm nut which holds front wheel bearing on? This is for a 2001 Grand Caravan.
    Thanks,
    John
    Nov 2003
    936
    I just run it on until the impact wrench stops ;-)
    Larry
    Jul 2003
    High Ridge, Missouri
    4,760
    From the Service Manual.
    (5) Install the hub nut on the end of the stub axle.
    With aid of a helper applying the brakes to
    keep the front hub from turning, tighten the hub nut
    to Install the mounting bolts and tighten to 244 Nm
    (180 ft. lbs.) torque.
    Avatar: EconoVoyager Concept
    Nov 2003
    South Hills of Pittsburgh, PA
    1,298
    I was going to say 180 ft lbs from memory (as I just did one) but DSM beat me to it!
    Chas
    Chas Stokes
    2000 Saturn SL1 "ZUUL"
    2002 Hyundai Elantra (Stolen ) "ZUUL24"
    Feb 2004
    Greenville SC
    317
    is replacing a front wheel bearing fairly easy to do? ive got a roaring up front when i turn to the right or slightly turn the wheel to the right at high speeds.
    1996 Chrysler Town and Country LXi 3.8l 115,000
    1997 Buick Regal 3.8l 99,588 (totalled )
    1985 Buick riviera 5.0l 80,000
    1972 Lincoln Mark IV 460ci 114,000
    1989 Lincoln Town Car Signature 5.0 85,000
    2000 Buick LeSabre 3.8l 94,000
    Nov 2003
    1,298
    Quote Originally Posted by jase386
    Define easy.
    I followed the directions that I got from the internet and it was going well up to the point that the bearing hub assembly was stuck in the steering knuckle. I had to .... uh... coax the old one out.
    Putting it back together was frighteningly easy.
    Chas
    Chas Stokes
    Jul 2003
    4,760
    3 pound or 5 pound coaxer?
    Nov 2003
    1,298
    Quote Originally Posted by DSMLVR
    I believe 8 pounds was the one I had on hand.
    Same one that 'coaxed' the rotors off my saturn.
    Chas
    Chas Stokes
  1. New Wheel Hub Bearing Assembly vs. New Bearing
    By vanbeater in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 07-05-2010, 10:09 AM
  2. Front wheel bearing help
    By xitrum08 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 06-01-2010, 05:12 PM
  3. Front rotor thickness spec-
    By 392hemi in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 06-29-2008, 11:36 PM
  4. front wheel bearing or hub assembly replacement?
    By mikesam in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 03-25-2008, 09:08 PM
  5. Front (drivers?) wheel bearing?
    By macinco in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-04-2007, 08:45 AM
