Bypass pipe from return radiator hose to engine j
Results 1 to 3 of 3
Thread: Bypass pipe from return radiator hose to engine j
    Jun 2009
    Brandon, FL
    1
    Question Bypass pipe from return radiator hose to engine j
    Bypass pipe from return radiator hose to engine is leaking at engine point. Took it off to find that O-ring is almost gone and edge of pipe has missing points or broken off areas. I can not find either the O-ring or this pipe. I have a 1999 Dodge Caravan and I don't have much money to put into van, but need it to take husband to Dr. (stroke 5 yrs now) Any advise or information would be most appreciated.
    Jun 2009
    Dog House (aka Garage)
    521
    Quote Originally Posted by nanna26angels View Post
    what engine? what year? what pipe? a picture sure would help. If I have the part you need I can send it cheap
    Jul 2008
    Under my vehicle
    122
    If this pipe is on the lower part of the radiator, it is called the "water inlet tube". It has an o-ring on the side that goes into the water pump inlet.
    I've only found the part at the dealer, and it contains the o-ring.
    If you can't afford the dealer version, you can go to a salvage yard -- there are usually many vans of this vintage -- and see if there is something workable.
    If I misinterpret your problem, apologies.
  1. Lower Radiator Pipe and Hose
    By markho in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-15-2012, 08:40 PM
  2. Radiator Hose replacement?
    By spoondoggy in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 06-10-2010, 12:35 AM
  3. Power steering return hose
    By dgtc in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 04-29-2010, 07:38 PM
  4. Air in radiator hose?
    By Jonno in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 06-25-2009, 08:21 PM
  5. Reasons to bypass the Radiator tranny cooler
    By tcwagner1 in forum 1st Generation Chrysler Minivan: 1984-1990
    Last Post: 02-18-2009, 08:53 AM
