Hot smell after driving around.
Results 1 to 9 of 9
Thread: Hot smell after driving around.
    Apr 2009
    Sarasota, Florida
    17
    Last weekend I pulled into my garage after being out and about for an hour or so and I smelled somthing coming from the van. It smelled like burnt plastic or a hot glue gun. I checked the Temp gauge, it was not hot. Oil and water level is good.I took it in today for an oil change and my guy checked the belts and the exhaust system. He said it looked good. Any idea what it could be. We can only smell it after driving. If you let run while parked for a while you cant smell anything at all. Weird
    Thank you for your time.
    2002 Chrysler Voyager 4 Cyl. 71,500K miles.
    Jan 2008
    Nova Scotia, Canada
    16,562
    Maybe brakes seizing / starting to seize. Check the temperature at your wheels when this happens or sniff the air (no big sniffs - bad stuff) near each wheel.
    Apr 2007
    SoCal
    5,293
    Sounds like something electrical heating up. If the smell is inside the van one common place to check is the climate control panel connection. The connector is known to melt with heavy blower motor use. Another would be the blower resistor block up behind the glovebox but only if you have the manual climate system. There was a recall on 02s (???) for water driping into the radio causing failures. Has that been taken care of? Are you seeing any system failures or querks? If you start smelling rotten eggs your cat converter could be over heating.
    Dec 2008
    1,985
    Have you opened the hood while it smelled? You might see some smoke rising.
    Jun 2007
    NW Illinois
    991
    Quote Originally Posted by first time minivan View Post
    Some smell is normal. The cat runs REALLY hot. You may have run over something (plastic bag perhaps) this is very common, may have a slight oil leak, do a little detective work. Sniff around the van in and out when you do smell it. Try to pinpoint a location. BTW make sure your parking brake is FULLY releasing.
    Apr 2009
    Sarasota, Florida
    17
    I can only smell it outside the van. I popped the hood and did not she any smoke nor could I smell anything. I will look harder next time. Not much odor today.
    Thank you
    Apr 2009
    Sarasota, Florida
    17
    No smke. Nor could I smell under the hood. Had the belts chewcked out, they are all in good shape. My mechanic said he could not see anything wrong under neath the van.
    Jun 2007
    Forked River, NJ
    565
    I had a pretty nasty smell when I would take the van on a long drive when I first got it. The valve covers were leaking oil, and probibly were for tens of thousands of miles as there was oil caked onto just about everything under the hood. I replaced the valve cover gaskets(as well as everything else to get to them). Then while replacing the gaskets, I saw that the guy that owned it before me took the wireharness out of the clips that go across the rear of the engine and the wire harness was laying on the exhaust manifold. Good thing I cought that in time!! No more smell.
    That might not be your case though. I would check the rear brakes and see if they are dragging. I had that problem with my old 05 GC.
    Apr 2009
    Empire State
    3,905
    Could you, by any chance, have driven over a plastic grocery bag or other piece of plastic that could have stuck to the exhaust piping / components?
    That would certainly cause the smell...
  1. The smell of Children....
    By Organized Confusion in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-26-2008, 12:48 AM
  2. AC/ Heater Smell
    By rwpurdy in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 05-21-2008, 10:41 PM
  3. a/c smell
    By mike johnson #4 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 07-24-2007, 09:37 PM
  4. smell
    By brownjug in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 11-04-2006, 02:37 PM
  5. smell
    Last Post: 09-19-2006, 03:35 PM
