I don't think they are supposed to charge you the deductible again if the first repair didn't solve the original problem.
2003 GRAND CARAVAN SPORT
1997 RAM 1500 SPORT 4x4
2003 ALERO
dun4now,
2000 Caravan 3 liter 118,000 klm. 17-20 MPG. New tranny at 97,000 KLM. Tires are P205 70R14 Bridgstone M+S. Here at 120,700 and no major problems, until now. 123,338 and replaced tensioner pulley, serpentine belt, and power steering pulley. No more belt chirp.
If your Airbag light is coming on as you turn the steering wheel or the horn/cruise control/radio are giving you problems at the same time then I would automatically suspect the clockspring. If none of that is happening your airbag light could be caused by a sensor/bag/monitor. A specialised scanner can determine what's up.
******** We took the time to answer your post. Please give us some time and post the fix. You'll help hundreds. ********
**** Follow all prescribed safety procedures before attempting any repairs. If in doubt, refer to a maintenance manual. ****
96 Gr Caravan LE 3.8, 206K miles
07 Fusion / 06 RAV 4 / 06 Accord / 94 Camry
Horn and cruise work fine. I have noticed however that the light on the dash for passenger airbag off is no longer lighting up when the seat is empty so I suspect a fault in the seat circuit.
1990 Plymouth Grand Voyager LE 3.3L LWB-- 198k miles and counting ......
318,650.1 kilometers, for you metric buffs ......
Horse Power = How Fast You Hit the Wall .....
Torque = How Much of the Wall, You Take With You.
Did all plugs and wires. Dealer did ignition coil. Starts hard and CEL is on again. It is staying at the dealer now until it is fixed. This is their fourth attempt. I suspect possible injector issue or cam position sensor but I did not pull codes to check. My reader/tuner is for Ford trucks.
They worked on it today and found nothing. Well nothing new anyway. They pulled plug one and it was wet just like I told them. They stuck it in cylinder 6 and the misfire moved so they replaced the plug again and cleared the codes. I bet the codes will come back when we drive it home (like they always do). The also had a multiple misfire code stored but not active? I suspect cam position sensor myself and I told them that. They said if the code comes back they will dig deeper. They were supposed to dig deeper today! I am going to find another dealer. Unfortunately most of the local ones were closed.
Anyone else think it could be cam position sensor?
Well, before replacing everything, I would suggest just swapping the two wires that are about the same size and see if it follows the wire, if not, likely the plug. But if you had it done under warranty and their fix did not fix it, they should not charge you another deductible. Call an arbitrator if necessary, but even the wires and plugs I believe they are under the emissions warranty until a certain point.
2005 T&C Ltd 3.8 69k
2000 Caravan 2.4l
1990 Grand Caravan 3.3 149,000 owned 15yrs 4 trannies
1990 Dynasty 3.0 120k 1 tranny 4yrs
1981 Dodge Aries 2.6 only new car I ever bought 225k orig 11yrs
1966 Dodge Coronet 440 Wagon, way old 1 yr. 135$ (Had to borrow it at the bank!)
1964 Simca 1000 (bought for $10 rebored) 50k 4yrs
1965 Ply Valiant V8 85k
1964 Ply Valiant Wagon slant 6 200k 1 qt/200 miles
1969 Corvair convertible 4 carb
All wires and plugs were already replaced.
We picked it up and less than 2 miles down the road the light came back on. We turned around and gave it back to them. I told them keep it until it is fixed or replaced. Looking at the receipt it appears that compression in cylinder one is lower than the rest but still within spec. I suspect a burnt valve or cam position sensor. This started at less than 36K miles and now we only have 42K. This is far too low mileage for this type of problem. The airbag light was the underhood sensor not the clockspring.
My F150 has 140K and has not had any engine troubles at all. I doubt we will be getting another Dodge.
Jeff http://www.facebook.com/eddie.munster
Current: 2010 Chrysler Town & Country Touring/3.8V6/38K/orig 62TE
2003 Dodge Grand Caravan Sport/3.8V6/118K/orig 41TE
1992 Chevrolet S-10/4.3V6/241K/orig 4L60E
