Battery Light-1997 Dodge Grand Caravan
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: Battery Light-1997 Dodge Grand Caravan
    Oct 2008
    17
    Hello,
    I have 1997 Dodge Grand Caravan with a 3.8 L engine. The van has 170k miles on it. I have owned the vehicle since it had 95,000 miles. I have only put a starter on it and maintained it with brakes, tires, oil changes, etc. The van has been very reliable and a good car.
    Last week, I had the voltage light (battery light) come on the panel. I took the vehicle to Advance Auto Parts. They put a machine on it and told me it was the alternator. I took the alternator out of the vehicle took it back to another Advance store that had the 120 amp alternator in stock. They bench tested the old one and they said it was fine. It was giving a solid 15 volts on the bench. So, I reinstalled it. Again, the light came back on. Took it off went to another advance and they bench tested and again it came up fine. Reinstalled it and it is currently on the vehicle.
    I put a voltmeter on it and when you start the vehicle the alternator is charging at 13.9 volts. You can drive it for about 1/2 mile and the light will come on. I cleaned the battery terminals, the grounds under the fuel rail and the battery case. There was a little movement on the ground under the battery. No change in the voltage light. I did the key test and no codes came up.
    Any suggestions ??
    Thanks,
    Patrick
    98 Dodge Grand Caravan 3.8 L
    170,000 miles
    Feb 2009
    Victoria BC Canada
    1,927
    Wink
    Quote Originally Posted by pburchins View Post
    Hello,
    Any suggestions ??
    Thanks,
    Patrick
    170,000 miles
    :hi 2:Hi Pat: Welcome to the forum. I just went out and checked mine before turning on the engine. My meter needle went to 12.5 volts with the key in the ignition but not running. When I started it it went to 14 volts and everything is okay. I read a similar post to yours a while back where they couldn't get a light to go out whether it was the check engine light or the battery light. They even erased the codes and reset the tcm, and the light would not go out. Then they replaced the bulb and that was the cure, go figure. Try leaving the battery unhooked over night and turning on the ignition in the morning and stepping on the brake to completely drain the tcm. Then try another battery if you can. Some times the least little thing you can do will fix it, and don't forget to post your victory so we can all see the fix.
    Nov 2005
    Fort Collins, CO
    3,895
    Arrow Welcome!
    Welcome to The Chrysler Minivan Fan Club Forums!
    Established in July of 2003, Glen Millar's Chrysler Minivan Fan Club has become the #1 online destination for owners and fans of America's favorite and best-selling minivan. We are very passionate about the Chrysler Town & Country, Dodge Caravan/Grand Caravan, and Plymouth Voyager/Grand Voyager vehicles we drive. Now with over 10,000 members from the United States and around the globe, we hope that our collective experience can be of assistance to you with your own Chrysler minivan(s), and we look forward to learning from your experience as well. After all, the more that is shared, the richer our community becomes. Here is some information that you may or may not have already heard that will help you get acquainted with the club and the online forums:
    As with any community we would ask that you review the legal and privacy policies for Chrysler Minivan Fan Club. The following link includes important copyright, affiliation and disclaimer information as well as the fan club forum's rule, guidelines and violation consequences. This information can be reviewed at http://www.chryslerminivan.net/legal.html. Click HERE to browse the Frequently Asked Questions portion of the site.
    First, a word about Technical Service Bulletins [TSBs] / Recalls. If you are new to the forum, please have your vehicle identification number [VIN] ready along with the make, model, trim and engine size [e.g. 3.3L V6]. Many problems can be resolved with a vehicle by making sure that it is up to date on all recall/TSB repairs. These repairs can be completed FREE of charge at your local authorized Chrysler/Dodge/Jeep dealer. You can check the recall status of your vehicle by calling your service department OR by going online: To do so, have your VIN number ready and go to http://www.chrysler.com/en/owners/ for all Chrysler brand vehicles, and http://www.dodge.com/en/owners/ for all Dodge brand vehicles. For all Plymouth brand vehicles, please contact your authorized Chrysler dealer.
    We would highly encourage you to pick up a Haynes/Chilton Repair Manual and/or Factory Service Manual [FSM] for your model year Chrysler minivan. They are available online, as well as at several retail auto parts stores. These books are a great reference and will save you a lot of time and trouble when working on your vehicle, it is money well spent! You may also wish to invest in one or more online services that offer the same or more information. A good one that I have had experience with is AllDataDIY.com. **Please Note: Third-party manuals are not guaranteed to have all of the information you might need to complete a repair, so you may need to consult several different sources in order to get the knowledge necessary to complete the job.
    Please take a moment to familiarize yourself with the forum's functions. Located at the top of the forum's page is the SEARCH function. This is a very powerful tool that can help you find the answer to several very commonly asked questions. I would advise you to make this your first stop before posting a new thread in the forums, as someone may have already asked your question previously and gotten an answer. You may have to try several different search terms, so please be patient! To say "Thank You!" to a member who offered useful information to you, you can click on the "Thanks" icon that appears in the bottom right-hand corner of their post.
    Finally, I would invite you to join the Chrysler Minivan Fan Club Online Showroom. Should you like, please take a digital photograph of your minivan from the front driver's side corner. Then, all you need to do is email the photograph in an attachment to chrisjcarpenter-31y2@post.me.com, making sure to put your forum username in the SUBJECT line of the email. Your photograph will be automatically uploaded to the showroom. Once you're done, go to www.tinyurl.com/d39osq to view the online showroom and see your vehicle on display amongst all of ours! [If you'd like to see some examples of pictures you can always view the showroom first!]
    Click HERE For More Information The Online Showroom
    Utilizing the "User CP" link at the top left corner of the page, please fill out your user profile. In addition, it would be most helpful to us if you would please include your vehicle(s)' information year, make, model, trim and mileage in your signature so we may reference it if need be on your posts. [e.g. "1996 Chrysler Town & Country LXi 123,456 Miles | 198 683 kms"] As always, should you have any questions, please ask.
    Again, welcome to the Chrysler Minivan Fan Club.
    -Chrysler1924
    Note: If you would like to advertise your business on The Chrysler Minivan Fan Club, there are several options available. This is a fun, inexpensive way to support this burgeoning community and promote your business. For more information, please visit http://www.chryslerminivan.net/advertise.htm
    Chrysler, Dodge, Jeep and Mopar are all registered trademarks of Chrysler LLC.
    Oct 2008
    17
    Quote Originally Posted by dun4now View Post
    Thank you for the welcome. Electrical issues are certainly one of the most frustrating problems. I took the battery out last night and will drain the TCM as suggested, thanks. I learned last night about the "key dance" and I never knew you could pull the engine codes by pressing the reset and trip buttons and turning the key. I am glad the forum is here to discuss our experiences.
    I noticed in your profile you are from Canada. I will have to buy you a cup of Tim Hortons the next time I head back north. Thanks for the tips.
    Oct 2008
    17
    I thought your suggestion was going to work.......Unfortunately, No.....
    I started the vehicle and the voltmeter read 14.1 and slowly it worked down to 13.5 while I turned on different accessories. I was hoping one accessory would be the cause. That was not the case. I turned on Lights, AC, Radio, Rear AC and all the electrical on and it stayed at 13.5 volts for 20 minutes. No Battery Light.
    I took it for a road test and within a 1/4 mile the light came on. Every time I road test it, the light will come on right at the same spot. So, it has to do with driving or the computer. I am open to suggestions!
    Mar 2008
    Southern WI
    381
    4
    Have you measured the voltage while the light is on? If it is actually low at that time then maybe there is a slipping belt or pulley on the alternator? Or maybe a loose plate in the battery shorting a cell after a short drive?
    Pat
    08 T&C Touring
    Previous vans:
    00 T&C 3.8
    95 GV 3.3
    89 Caravan 3.0
    Nov 2005
    Fort Collins, CO
    3,895
    Truth be told, I don't have much faith in the battery tests that AutoZone and the like do anymore. Just because I have had many problems with batteries in the past that have tested "Good" ... they have sent me on huge wild-goose chases as a result. The second I replaced the battery anyway? The problem went away. The net of it is, have you tried swapping out the battery just to see if the problem still persists?
    Part of me wouldn't be surprised at all if you replaced your seemingly "Good" battery, if the light went out and the problem disappeared.
    PS- how old IS the battery...?
    Oct 2008
    17
    Quote Originally Posted by monza View Post
    I put a new serpentine belt on last week so that is good. There are no noises coming from the alternator. Advance Auto Parts swapped out the battery and gave me a new one. Unfortunately, I drove 1/4 mile and heard the ding of the battery light.
    I am trying to be methodical about it and my logic is just not working. Thanks for the suggestions ! Keep them coming !
    Feb 2009
    Victoria BC Canada
    1,927
    Next suggestion, chase down a loose connection in the harness. If the light is only coming on when you drive and at the same spot suggests vibration on a loose connection. Does the light come on after a turn or while braking or excessive bumps in the road? Something to think about, the dreaded clock spring, has that ever been replaced.
    Mar 2008
    Southern WI
    381
    4
    Does the light stay on long enough to measure the alternator voltage while the light is on? Then what is that voltage (while the light is on)?
    Did the light ever come on before you got the new battery, or only just after the new battery was installed?
    If you provide the facts maybe we can add some logic.
    Pat
    08 T&C Touring
    Previous vans:
    00 T&C 3.8
    95 GV 3.3
    89 Caravan 3.0
  1. Grand Caravan 99 - Battery light on in cold weather
    By car crazy in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 12-31-2010, 06:36 PM
  2. ABS Light - 2006 Dodge Grand Caravan
    By GJ-2006 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 11-08-2010, 02:34 PM
  3. 2009 Dodge Grand Caravan Replace RKE Battery
    By rob.bittner in forum 5th. Generation Chrysler Minivans: 2008-2016
    Last Post: 08-02-2010, 04:53 PM
  4. 2003 Dodge Grand Caravan MIL Light ON.
    By DSMLVR in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 11-28-2007, 10:35 AM
