Front Engine Mount
Results 1 to 6 of 6
Thread: Front Engine Mount
    Mar 2009
    Minnesota
    26
    Unhappy Front Engine Mount
    I was changing oil the other night, and was underneath looking for leaks, when I notice that the engine is "shaking" somewhat. Well, to my eye, the front motor mount appears to be south. Anyone had to replace one?
    Nov 2008
    DeSoto County, MS
    2,926
    I'm in need of replacing the same one soon. It's getting pretty bad, the others seem to be ok. Hopefully someone can post and help us both out.
    May 2008
    Conover, NC
    41
    I've not had to do it, but I have the instructions from my Alldata sub:
    REMOVAL
    1. Support the engine and transmission assembly with a floor jack so it will not rotate.
    2. Remove the front engine mount through bolt from teh insulator and front crossmember mounting bracket.
    3. Remove six screws from air dam to allow access to the front mount screws.
    4. Remove the front engine mount screws and remove the insulator assembly.
    5. Remove the front mounting bracket, if necessary.
    It has specific torque for the screws/bolts, but uses a diagram to show which get what though.
    The bolts that attach the engine ount to teh lower radiator crossmember get 54 Nm (40 ft. lbs.), the front engine through bolt, and the 2 bolts that go in the lower part of the Engine mount bracket get 68 Nm (50 ft. lbs.), and the bolt that goes in the upper part of the engine mount bracket gets 102nm (75 ft. lbs.).
    Hope that helps.
    '99 Chyrsler Town & Country Limited, 144k
    Nov 2007
    141
    12
    did it recently
    Quote Originally Posted by heffe2001 View Post
    REMOVAL
    Sounds about right, it's very straight forward and easy to get to. My bolts were extremely tight, and getting the bracket to line up for installation was the tough part. It has slotted holes, so it's easy to line it up crooked. I imagine if it's not centered when you bolt it down it will fail quickly. It took away some of the bonking noises I was hearing.
    good luck!
    Thanks -- Erwin
    '96 Chrysler Town and Country LXi
    Oct 2008
    Arizona, USA, and Elsewhere
    3,508
    Cool
    While you're under there, also check ALL the other mounts, including the Tranny mounts. If one went, the others may not be far behind.
    You didn't share any vehicle specs, but I replaced ALL mine at 167kmiles.
    Still Going Strong
    Mar 2009
    Minnesota
    26
    Sorry, I forgot to give my vehicle specs.
    It's a '98 T&C LXi w/ 212K miles.
    Runs like a top.
  1. front Motor Mount
    By clok1966 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 10-20-2010, 01:06 AM
  2. Gotta replace an engine mount- how?
    By dspahn in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 05-29-2010, 07:08 PM
  3. Front Engine Mount
    By hemmi in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-08-2009, 05:02 PM
  4. Looking for tips/tricks on transaxle and front engine mount replacement
    By efficacyman in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 05-26-2008, 11:41 PM
  5. Engine Mount Change
    By Zuul24 in forum The Fireplace
    Last Post: 12-03-2004, 12:57 AM
