Engine fuse keeps blowing (20Amp)
Results 1 to 7 of 7
Thread: Engine fuse keeps blowing (20Amp)
    Nov 2008
    DeSoto County, MS
    2,926
    Question Engine fuse keeps blowing (20Amp)
    A friend of mine has a '97 Plymouth Grand Voyager. She was driving it and it turned off...turned out to be the "engine fuse" which is a 20Amp fuse under the hood. Her husband replaced it and all was fine again. Well 1 week later the fuse blew again. I know my van wouldn't run when I pulled the fuse and I got an ignition coil check engine code (I did it just to see what happens). What would cause this fuse to keep blowing on her van?
    Apr 2007
    San Diego
    5,243
    Can't say for sure but it sounds like the autoshutdown fuse number 12. The fuses on my schematics are numbered and not "labeled". This fuse conducts power to the autoshutdown relay coil and output contacts, O2 sensor heaters, fuel injectors and PCM. Tough to troubleshoot intermittent problems. For now you could inspect connections and wire harnesses for corrosion/chaffing/security. Disconnect the battery first to prevent PCM damage. If it come to swaptronics as a fix, try a junkyard for the cheapest way out.
    Nov 2008
    DeSoto County, MS
    2,926
    Quote Originally Posted by RIP View Post
    Well this fuse is labled 'engine'. Is that the one you're talking about?
    Oct 2008
    Arizona, USA, and Elsewhere
    3,508
    Lightbulb
    Check your O2 sensor wiring. It's near the exhaust and if it touches, it'll burn through and cause an intermittent as you hit bumps. Also check all wiring anywhere NEAR the exhaust. There's many other wires that hang near the exhaust that can touch and short as the van bounces around.
    Still Going Strong
    Nov 2008
    DeSoto County, MS
    2,926
    Quote Originally Posted by AzTraveller View Post
    I'll let them know to check this stuff out....someone mentioned to them to replace their cam position sensor....don't know what that would have to do with anything.
    Apr 2007
    San Diego
    5,243
    Quote Originally Posted by sideburns2009 View Post
    As I said, I can't be sure but, the engine control schematics I'm referencing show two 20 amp fuses in the PDC under the hood. One is as stated and the other conducts power from the hot battery bus to the fuel pump relay switch contacts and on to the fuel pump. It also supplies B+ power to the PCM.
    May 2011
    1
    20amp engine fuse blowin
    I just ran into this problem. I unplugged the connector to the coils replaced the fuse and it blew. So I inspected all connectors on the circuit. I noticed the o2 sensor connectors were burnt from the exhaust. I removed the upper intake cut the original wires and replaced it with a universal o2. I put every thing back together, replaced the 20amp fuse, start her up and good to go.
    P.S. buy a new upper intake gasket and big box of 20amp fuses to be on the safe side.
    If this is'nt your problem you will need the fuses to keep testing all componets on
    circuit till the fuse stops blowing then you found the problem. Don't buy anthing
    else till you done all possible tests to find the problem.
  1. Engine Fuse Blowing?????
    By broski64 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 06-20-2010, 03:41 PM
  2. 1997 minivan keeps blowing engine fuse???
    Last Post: 06-01-2010, 06:28 PM
  3. '97 Ram blowing 'engine' fuse
    By sideburns2009 in forum Chrysler Light Trucks
    Last Post: 04-29-2010, 02:45 AM
  4. Blowing A/C Fuse
    By jkemp in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 06-23-2009, 05:41 PM
  5. Keep blowing fuse # 8 - 10A under dash
    By BobDiane in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 04-20-2007, 09:03 PM
