Engine rattle on acceleration
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: Engine rattle on acceleration
    Apr 2009
    Memphis TN
    5
    Greetings,
    1997 Chrysler T&C 190,000 miles. Driving back from Chicago 3 weeks ago I started noticing a rattle when the engine would upshift at highway speed (on cruise control), even in the slightest hill. I have also noticed the same noise for a few seconds when first turning the engine on in the morning. My first theory was the knock sensor (does the knock sensor give an error code if not working?), either way I changed it but the rattle continues, it is definitely on the "front" of the engine (pass. side). I tried the "garden hose" method but I cannot find where the rattle originates. Any suggestions?
    Oct 2008
    Arizona, USA, and Elsewhere
    3,508
    Cool
    Sounds to me like a rod bearing, or collar. Wouldn't hurt to plan a rebuild, or engine swap.
    Still Going Strong
    Apr 2009
    Memphis TN
    5
    Thank you Traveller. What is the life expectancy of one of these 3.8 engines?
    I am religious about doing the proper maintenance. What year engines could be candidates for a swap? Thank you again!
    May 2006
    New Hampshire
    8,368
    Quote Originally Posted by Don Carlitos View Post
    Do not in any way jump to the conclusion that you need to rebuild your engine as the 3.8 liter engine (and its virtually identical 3.3 sibling) are well known for being able to deliver hundreds of thousands of miles with just regular maintenance.
    As for your rattle, there are several ways in which you might diagnose the noise including the garden hose method (although you might have to figure out how rig it so that you can listen while you drive) or find a garage that has those new radio transmitter listening devices that they can stick all over the engine compartment to isolate the location of a noise. Your problem could be as simple as resonance in the exhaust system, a bad motor mount or any number of other relatively inexpensive to fix problems.
    Oct 2008
    3,508
    Talking
    The 3.3L & 3.8L are essentially the same engine, but different bore and stroke. Some engines will last 400kmiles (no one has commented about rebuilt in the interim), others may go sooner. I rebuilt mine around 167kmiles. The rings were all carboned up and the mpg was suffering. We have a crappy "blend", here, to make our "smog" indistinguishable from the stuff that blows in from California.
    Most of the feedback on the forum is "They last a very long time" !!!
    They really "ARE" good engines.
    The major differences over the years are "intake manifold" and "exhaust". If you keep your wiring harness, as well as intake and exhaust, you can easily swap in most any "long block" (flex or not). You may wish to stay near the same year as yours or newer, there may have been some sensors that might have been added on the block that may not be on the older blocks (no place to mount them).
    Several people have done engine swaps, and I'm sure will share their "hands-on expertise" with you. Give them a few days to check the forum.
    As to rebuilding, the Haynes manual is very straight forward. I did mine in 3 weekends, in the van. 1st) to dismantle, send out heads for check and rebuild. 2nd) hone cylinders and prep everything, get new parts (inc: headbolts & intake bolts, front and rear main seals). 3rd) put it back together. You'll want to do the water pump, tensioner & pulley, static idler pulley, t-stat, and radiator cap (lever type), plugs, wires, hoses, injectors, while you're there. Consider your Alternator and power steering pump, if you haven't already replaced them, as well. They're much easier to do now, than later. Check the TSB's on the fuel rail and rail hoses, you may need to replace them, as well.
    You'll be good for another 190kmiles.
    Have you had to rebuild your tranny, yet?
    Still Going Strong
    Jun 2007
    NW Illinois
    991
    First is there any performance issue(s)? If not when was the last tune up? You may also have nothing more than an exhaust leak. Perhaps a bad donut or cracked/loose exhaust manifold or a cat con that has loose substrate even a bad muffler.
    Jan 2008
    Nova Scotia, Canada
    16,478
    Greetings,
    Internal rather than external
    Heat shield
    Did you take the oil filler cap off and listen there?
    Jul 2003
    High Ridge, Missouri
    4,760
    May even be a case of bad gas and you may be getting engine Ping or knock.
    Avatar: EconoVoyager Concept
    Jun 2007
    NW Illinois
    991
    Quote Originally Posted by DSMLVR View Post
    Could be..........you should hear the noises I make when I get "bad gas"
    Jun 2005
    KS
    1,291
    2
    Torque converters have been known to knock...
  1. Engine Clank/Rattle [3.8L V6 EGH]
    By Chrysler1924 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-28-2014, 01:21 PM
  2. 09' 4.0 Town and Country cold engine start rattle
    By erazzid in forum 5th. Generation Chrysler Minivans: 2008-2016
    Last Post: 01-22-2010, 01:05 PM
  3. 2001 T&C - Engine Rattle Trouble Shoot with Video to help
    By newstwome in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 07-09-2009, 12:04 AM
  4. engine rattle
    By nafman in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 09-01-2008, 09:47 PM
  5. Engine Rattle/knock when acc from low speed
    By Rowe05TC in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-06-2005, 06:55 AM
