rear heater tubes rotted through.I was considering bypassing the rear heat,because the tubes to replace are very expensive.but after doing some research,and talking with mechanics,I decided to relace the tubes with heater hose.the section of tube that had rotted through was along the fire wall and came down the right rear of the engine.anyhow i took a dremmel tool and cut out the bad sections of tube on the supply and return lines.a little dificult due to the tight space but didn't take to long.I bought good heater hose and clamps and installed them,I also put on plastic wiring harness over the hose to protect it form road debris.i then put on zap straps and connected the hose to the rear a/c lines so they wouldnt be flapping around.Due to losing alot of coolant I also flushed the whole cooling system(which had needed to be done).and replaced with new coolant.It has been about 2 weeks since I did this repair and all is fine so far.have no leakes.and rear heat works well.the whole process took a few hrs but was worth it to have the rear heat.and was not to difficult.although I live in a fairly mild climate(vancouver island,British Columbia) it is very damp,in the fall winter and spring.so having the rear heat is more to keep things dry and to not get mildew.well if anyone one else has this problem,it is a good DIY fix.
