A/C evaporator repair with pictures
Results 1 to 5 of 5
Thread: A/C evaporator repair with pictures
    Apr 2009
    7
    Here is an article I made to show the process of replacing the front air conditioning evaporator in a 2000 Dodge Grand Caravan:
    http://dodgeforum.com/forum/dodge-ca...-pictures.html
    As you can see it was a chore!
    Oct 2008
    Arizona, USA, and Elsewhere
    3,508
    Question
    Quote Originally Posted by mr_mahoney View Post
    Good picture. What prompted you to replace it?
    Still Going Strong
    Jan 2008
    Nova Scotia, Canada
    16,449
    That's a job and a half. Any consideration to cutting a hole in the floor / fire wall area?
    Must have had a few pieces left over after re-installation?
    Nov 2008
    DeSoto County, MS
    2,926
    I wonder if this was as difficult as it was to replace the rear evaporator in my '94 (whole left side interior, seats, and seatbelts had to come out. Probably more difficult. I hope I never have to do this.
    Edit: just got done looking at the rest of the pictures. this looks about 10x harder than what I did. That's the BCM in the floorboard isn't it?
    Feb 2008
    Canton, Michigan
    497
    When our '97 T&C was diagnosed with a corroded-thru evaporator, and I found that the only way was to pull the entire dash, it was a quick decision to let a shop do the work. From what I see here, it was $700 well-spent. As I recall, the dealer wanted a lot more than $700 (I went with a recommended shop). The guy said they had done many of these evaporator jobs on fleet vehicles. It's common for condensation to settle in the bottom (poor drainage) and rust it out.
    No way could I do that in 12 hours! You must be quite organized.
    Our current '00 GVoyager had leaking A/C condensers (both main and aux/rear). After I replaced those, I was literally holding my breath when we tried pulling a vacuum. My nightmare was putting money into condensers, only to find out the evaporator was bad, too. But I was relieved.
    2000 Chrysler Grand Voyager SE (3.3L Flex Fuel "G")
    Purchased January 2008 @ 80,000 miles
    Options: 2nd row buckets, rear A/C
    Mods: Full upgrade to 8-speaker Infinity audio; hitch, wiring, brake controller, sway controller, & WDH kit for towing 3000 lb popup camper
    R&R: 1 front & 1 rear hub/bearing, front sway bar bushings & endlinks, 1 outer tierod end, trans-shift solenoid pack, main & aux/rear A/C condensers
  1. Rusted Brake Line Repair -- Best Way to Repair?
    By gnode in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 03-21-2010, 08:52 PM
  2. evaporator
    By moezy in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 06-24-2009, 07:28 PM
  3. evaporator
    By jram in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 02-01-2009, 01:05 AM
  4. Evaporator
    By jasonldrummer in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-28-2008, 03:08 PM
  5. AC Evaporator Leaks
    By trcar54 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-17-2006, 04:39 PM
