Power vent fuse?
Results 1 to 10 of 13
Thread: Power vent fuse?
    Apr 2009
    2
    Power vent fuse?
    Hi
    I have a '98 Grand Caravan. The rear power vents spontaneously stopped working last night, both at the exact same time. I used to hear the motors working and now when I hit the switch there is no sound at all. I can't seem to find a fuse for these. Any ideas where that would be. I read the forums about replacing motors and switches but hoping to avoid this if possible. Thanks for the help.
    Nov 2005
    Fort Collins, CO
    3,895
    I bet the switches on the door are bad. This happened to both of my own 3rd gens. A vent, or both vents started working sporadically, and then less and less, and then not at all as the switches failed. Currently I don't have much of a need for the rear vents, so I haven't bothered to rip the door apart and change out the switches. But I would gaurantee that this is where you problem is. I kept thinking it was the motors, but not so!
    Jan 2008
    Nova Scotia, Canada
    16,494
    Quote Originally Posted by mat View Post
    Hi
    Are you talking about the rear blower motor for heat? What's the other motor? Will they work on high, if so a resistor block or power module (automatic temperature control) is likely faulty.
    Apr 2009
    2
    The rear power vent windows is what I am talking about, sorry.
    Feb 2009
    Halifax Nova Scotia
    140
    Yeah that sounds like the switches ,it takes about 2 minutes to remove the switches and you dont have to pull the door panel off, just a couple of screws and unplug the switches,find another set to borrow and switch them around to see if thats the problem. Easy job alls you need is a phillips screwdriver,could just be your plug is loose or dirty contacts!
    1999 Plymouth Grand Voyager Se AWD
    152,345 km 3.8 engine.
    Feb 2007
    Lancashire, UK
    913
    2
    The supply fuse for the power vent windows is in the PDC next to the battery.
    It is the middle one (position five from the front) of the nine big fuses, and is rated at 40 amps.
    '97 Chrysler Grand Voyager 3.3 LE (UK Model) , 167,000 miles. Dual Fuel Petrol/LPG. Tow Pack.
    Now sold. New owner is using as a project ! Replaced by a 2000 Nissan Primera 2.0L Sport+
    Apr 2007
    San Diego
    5,240
    Trouble is, according to a 98 schematic at least, if any "fuse" in the system blows, it will effect all the windows and not just the vent windows.
    BTW - All I'm seeing in the system are PTCs (thermal circuit breakers). No fuses. Two on the junction block under the dash, one in each of the motor assemblies.
    Apr 2007
    San Diego
    5,240
    Switches? Two seperate switches going bad at the same time. Hmmm. About the same as two motors failing at the same time. I'd lean towards a problem in the circuit board in the switch assembly. Change that and you change the switches anyway. Maybe I'm "splitting hairs".
    Feb 2009
    Halifax Nova Scotia
    140
    oops sorry I was replying to another thread about a passenger door switch not working,got ahead of myself,oh well this may solve your problem to,like I said it only takes minutes to check out the switchblock with another,try to find one from a donor vehicle.
    Feb 2007
    Lancashire, UK
    913
    2
    Quote Originally Posted by RIP View Post
    Agreed. Which make it strange that only the Vents have stopped working.
    From the Chrysler service manual CD:
    HELPFUL INFORMATION
    ² Check the two 9 amp PTC’s located in the junction
    block (positions 8 & 9)
    ² Check the 40 amp fuse located in cavity 5 of the
    PDC
    ² Check for a good ground at the instrument panel
    left side cowl
    Could this be a bad ground, or a bad ground wire from the switches ?
  1. Adding rear power Vent Window Motors to a Base 4th gen
    By JCamasto in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 06-30-2011, 02:30 PM
  2. Help with fuse position in power center
    By fdm2000 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-13-2010, 10:53 AM
  3. Fuse to DISABLE the power opening doors?
    By GreyDawg in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 11-29-2008, 01:38 AM
  4. 05 Power Seat Fuse
    By bccpks in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 07-13-2008, 05:47 PM
  5. Power vent window stuck open
    By Bajohns1 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 07-06-2008, 12:34 PM
