Transmission pan bolts stripped
Results 1 to 10 of 15
Thread: Transmission pan bolts stripped
    Nov 2007
    141
    12
    Question Transmission pan bolts stripped
    For the first time since I've owned the van, I dropped the transmission pan to change the filter. 4 of the bolts were cross-threaded and stripped and the previous mechanic had just glued the whole thing back together with black silicone, no gasket. What should I do? try as is, and hope the remainder of the bolts hold it tight enough? Drill and tap the offenders to the next step up?
    Previously I was just siphoning 4 qts out, and adding 4 new qts without changing a filter. I now wish I had done the same again
    Thanks -- Erwin
    '96 Chrysler Town and Country LXi
    Sep 2008
    562
    5
    Probably the best repair in this situation would be to install "Helicoils" in the damaged locations. I wouldn't trust 4 missing bolts not to allow leakage.
    Dec 2008
    1,985
    And I would install a drain in the pan so it wont have to come off again for a long time.
    Jan 2008
    Nova Scotia, Canada
    16,539
    RTV sealant is the norm and it forms a silicone sealent. Gasket isn't the norm.
    Stripped bolts, yikes. Need to get those bolts somewhat tight. Drill and tap if that is the easiest route. Wonder if there are studs you could put in there.
    Oct 2003
    Niagara Ontario
    825
    In the past I have just put in longer bolts to catch the remaining threads.
    Hank
    07 Dodge Caravan SXT 3.3L Gold 135,000 kms
    05 Dodge Caravan SE 3.3L Silver 200,000 kms now sold and replaced with a 13 Journey.
    84, 89, 93, 94, 95 Chrysler minivans in my past, all served me well and are long gone.
    90 Shadow long gone
    Jan 2008
    Nova Scotia, Canada
    16,539
    Quote Originally Posted by Hankster View Post
    Hank
    It that case, maybe J-B Weld and studs will work for a more permanent stronger fix.
    Nov 2007
    141
    12
    Thanks!
    The bolts were very tight when I took them out, that must have stripped them. I tried to get to the untouched threaded section with longer bolts, but there's not much there, much it already buggered up with silicone, and the bolts were just coming back out with coils of thread stuck to them. Not a very strong alloy for the case, if you ask me. I noticed a crack near where the side panel bolts on, too. I hadn't realized the silicone was standard, since a gasket came with my filter kit.
    Quote Originally Posted by Jeepman View Post
    I'm going to try that this afternoon. Then I'll leave the pan alone for the next 100K miles, and just periodically siphon through the dipstick filler. Thanks all!
    Thanks -- Erwin
    Jun 2007
    Forked River, NJ
    565
    Quote Originally Posted by paart View Post
    I will second this! They are more expensive than the cheap fixes that "might" hold, however they are a PERMINENT fix. I did this to my Saturn's valve cover cause 3 of the bolts were stripped when I took it off. If you do it this way, the best thing you should get is a bottom tap(a tap that hat threads all the way down the shank). This way you can get it all the way in and not have to worry about the length of the bolts.
    Nov 2007
    141
    12
    Smile JB weld holds so far
    I don't know if they'll ever come out. Those studs felt so much sturdier to torque, I'm scared of the little bolts now, I want to convert all of them. No leaks detected yet.
    So the filter doesn't need changing for 100K? What about the ATF4?
    Thanks -- Erwin
    Jan 2008
    Nova Scotia, Canada
    16,539
    Quote Originally Posted by ArtBasement View Post
    J-B Weld is very strong and tenacious. I believe my Neighbour, who has an old 1953 Dodge Power Wagon ex-military 3/4 ton army truck, which he uses for snow ploughing (commercially) and for hauling fire wood for himself, has the vehicle held together with it.
    Were there any threads available for the studs to thread into?
    Pan drop and filter change are covered in the Owner Manual. I am changing around 100,000 kms rather than 100,000 miles (easy to remember), which is a little sooner than need be. 100,000 miles should be fine, the fluid was designed to outlast 100,000 miles.
  1. Lug bolts
    By black95jimmy in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 04-27-2010, 07:54 PM
  2. Cam bolts?
    By KillaGrn in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 12-02-2009, 01:39 AM
  3. Loose oil pan bolts again?
    By niceguy in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 07-06-2009, 09:37 PM
  4. Transmission Pan Bolts
    By MattsMinivan in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 06-21-2009, 08:08 PM
  5. Where to buy replacement bolts - Yep, I broke one
    By edvan22 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-23-2008, 12:02 PM
