Sliding Door diffilcult to slide.
Results 1 to 10 of 10
Thread: Sliding Door diffilcult to slide.
    Mar 2009
    6
    Smile Sliding Door diffilcult to slide.
    I have a '95 Dodge Caravan and the sliding door is very diffilcult to open and close. I've put some silicone/greese spray in this area though it didn't help. I assume there are bearings in here that are shot though I'd like a little advice before I try to take this apart and then don't have a vehicle to drive because the parts aren't in or some other Murphy's Law thing that is sure to happen if I'm not prepared up front. Any advice appreciated.
    Mar 2009
    minivan down by the creek
    422
    I would say look at the 3 roller hinges and look if the rollers are rolling, if they are siezed, you can take each out out one at a time and try to free them up or just go junkyard hunting or post on here to buy some that are good. According to body shop estimator it wont take but a hour to switch with experiance and figure a couple hours for a novice I looked at my 1994 Town and country to see that they are fairly easy to access with a 10mm socket wrench
    Jan 2008
    Halifax Nova Scotia
    1,224
    Try spraying the roller bearings with WD-40 to free them up. Silicon and grease just gum up the bearings at times and they wont turn properly when in use.
    1994 Dodge Caravan SE 3.0L 448,000km and counting
    1978 V8 AMC Pacer DL(sold my 16 yr love affair)
    1974 AMC Gremlin
    Oct 2008
    Arizona, USA, and Elsewhere
    3,508
    Talking
    Quote Originally Posted by V8Pacer View Post
    x2 what V8pacer says. The WD40 flushes the dirt out, as well as lubricates the bearings. I use WD40 periodically on my sliding door bearings, latches, and have had no problems in 20 years.
    Still Going Strong
    Jan 2008
    Halifax Nova Scotia
    1,224
    i have also found that some times if the door is rarely used the bearings get a healthy coating of rust buildup and tends to make them not work well.WD40 will break the rust up so they will be freed and can start to roll properly again.
    1974 AMC Gremlin
    Dec 2003
    Eau Claire, WI
    2,800
    I will usually use some WD-40 in the rollers to break up any rust in there, followed by some white lithium grease.
    Kevin Peterson
    Senior Global Moderator
    Chrysler Minivan Fan Club Forums
    "In a completely rational society, the best of us would be teachers and the rest of us would have to settle for something else." -- Lee Iacocca
    Nov 2008
    DeSoto County, MS
    2,926
    Well, the rollers weren't rolling on my 3rd gen. I sprayed them with PB blaster and they immediately started rolling smoothly again. The sliding doors are 10x easier to open and close now, and don't require slamming to get them to latch.
    Jan 2008
    Halifax Nova Scotia
    1,224
    Quote Originally Posted by sideburns2009 View Post
    PB Blaster and WD40 are both excellent products to use in this situation.
    1974 AMC Gremlin
    Nov 2008
    DeSoto County, MS
    2,926
    Yep. I like the penetrating action of PB Blaster though, it really does what it says, which is surprising with most products sold today. Try one of the 2 products on your door and let us know how it works out.
    Jan 2008
    Halifax Nova Scotia
    1,224
    I have never used the PB Blaster but have been tempted to but it just to see if it really does as it says.
    1974 AMC Gremlin
  1. 2006 T&C sliding door not sliding
    By lipskidder in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-09-2010, 08:01 AM
  2. Power slide pass.side door won't open.
    By Duker in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-03-2010, 12:46 PM
  3. sliding door
    By tccstahlman in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-16-2008, 12:11 PM
  4. '05 T&C Passenger Side Power Slide Door
    By DEK in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 03-20-2007, 07:18 PM
  5. Sliding Door Help
    By PFury in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 01-21-2005, 04:56 PM
