Trans fluid and dipstick
Page 3 of 7 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 69
Thread: Trans fluid and dipstick
  1. #21
    Mar 2009
    Temporary Insanity, PA
    1,149
    Slightly reminiscent of "No user serviceable parts inside" on most electronics.
    2000 Caravan - "Cara" - 2.4/31TH - 128,XXX
    0w30 Mobil1 Syn, SRT-4 oil filter, roof rack delete.
  3. #22
    Apr 2008
    Gouldsboro, Pa.
    396
    Quote Originally Posted by Rschrei518 View Post
    If i recall on the 3.8 there is a pipe under the hood which i believe comes from the transmission with a cap on it which says i believe do not remove dealer use only. This is where i would think the tranny fluid gets added any thoughts? i don't have the vehicle with me now but i do remember seeing this.
    You are correct. That cap is where the dealer inserts their scan dipstick tool . You can add some fluid there, however, without knowing how low the fluid is, how do you know how much to add?
    2011 T&C Ltd. White Gold, Dark Frost Beige/Med. Frost Beige Interior. Nav., power rear seat, Load Leveling Suspension
  4. #23
    Oct 2008
    Arizona, USA, and Elsewhere
    3,508
    Talking
    Quote Originally Posted by Christ View Post
    1. If you can change the filter, it's not sealed.
    2. If you don't have a dipstick, and the tranmission was sealed before you opened it to change the filter, where are you going to add the fluid? (Not counting those which are simply older transmissions with a plug where the dipstick used to be... you can just add the dipstick back in for those.)
    The term "Sealed" references not having a "dipstick". You remove the dipstick on your tranny and plug the hole, it's considered "sealed". That doesn't mean you can't change the filter, does it ? Once the filter is replaced, you remove the "plug" and refill it with the appropriate quantity, then put the plug back.
    Still Going Strong
  6. #24
    Dec 2004
    Virginia
    4,029
    without a dipstick, how do you know how much is "the appropriate amount?" If you are draining and refilling, there's some fluid that doesn't get drained. So drain, measure, and refill with the same amount you drained, right? but what if there's a leak?
    Give me a dipstick anyday. I may not use it, but it's nice to know it's there, especially if I find transmission fluid on the outside of the pan, or on my garage floor.
    Michael
    Centreville, VA
    Currently driving:
    Former owner of:
    Other vehicles:
  7. #25
    Nov 2008
    DeSoto County, MS
    2,926
    Well if there does happen to be a leak under your 5th gen, I would call up the dealership and demand they have it towed back for repair, cost free of course because it's warranty work, because if it's leaking and there's no dipstick for me to tell if it's dangerously low, then I would refuse to drive it to them. No dipstick would drive me crazy, I'm OCD about my fluid levels and check them frequently.
  8. #26
    Feb 2009
    Ottawa, Canada
    91
    Quote Originally Posted by sideburns2009 View Post
    I'm with you on the dipstick idea! Believe me I was born and raised in Ireland and drove standard transmission cars from 16 until I left in 2001. I never had a problem with a transmission in Ireland at all with any of the cars I owned.
    I come to Canada and I have actually replaced 3 auto transmissions so far!
    On all the cars in Canada the dipstick is the only way to try to prevent the auto trans from dying as they all develop leaks from somewhere. I check the dip sticks every month and if I see a change from the norm I jack the car up and find out why!
    1999 Chrysler T&C Limited AWD 250,000kms
  9. #27
    Jun 2007
    Mississauga, Ontario
    4,874
    Quote Originally Posted by rayodunne View Post
    Me too! My ex van was once jumping out of D position. The fluid was very low and terrible dirty... they flushed it using a special pump to be sure all the fluid is replaced, replaced the filter and... it never happened again.
    My T&C transmission was replaced in US when it was under warranty after attempting to fix it twice. The US dealer told to the ex-owner not to touch it until the new transmission will be 7 years old (end of warranty).
    In 2007 when I bought it, the US warranty was lost by bringing the van to Canada. After 1 year, I decided to check the fluid level and... surprise: I had to add 1 liter of fluid to bring it to the required level. How could I know to add 1 liter only and not more or less. No leaks were noticed on my garage floor...
    Standard transmissions are a completely different story, you can not compare them with the automatic ones. Those ones did not have a deep stick anyway. On them, the repercussions of loosing some fluid are much less dangerous. The fluid on standard transmissions has a lot easier job to do!
    Overall it is known that standard transmissions are much more reliable and usually they over live the car's life
    2002 Town and Country LXI - 3.3L - 160,000 miles
    1988 Dodge Grand Caravan LE - 3.0L - 273,000 miles (Gone but never forgotten)
  10. #28
    Jan 2010
    winterville, GA
    221
    The dealer does use a dipstick (special tool!) to check fluid level. Scan tool is used to check transmission temperature to know proper level of fluid on the "special tool". A load of BS in my opinion. I will be looking into fabricating a usable dipstick myself.
    Audis are another matter. Those are checked and filled from the bottom. Daughter has one of those unserviceable things.
    '87 Caravan LE 3.0, '91, '92, '93, '94 Grand Caravan LE 3.3
    '02 T&C Limited 3.8, '09 T&C Limited 4.0
  11. #29
    Jun 2009
    Jefferson City, TN
    3,051
    If your worried about your transmission fluid level, call your dealer and schedule an appointment to check your transmission fluid level. They'll do it.
    We have some customers that request a level check at every oil change. No problem.
    Also I'm surprised some company has not came up with a dipstick to put in the tube that the transmission has. I can't imagine someone has not... I'm sure it is on the drawing board somewhere... if not already available.
    Jeff
    Current:
    Previous minivans:
  12. #30
    Aug 2009
    Kitchener,ON,Canada
    23
    Sealed trans is not reparable,it replaceable only part and it cost a fortune ($4000).Not a single trans shop take to repair,only to replace.Ford is recently drop from production this kind of trans.
  1. trans fluid level
    By baroth1 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 09-11-2010, 07:08 PM
  2. Trans fluid leak 99 T&C Ltd 3.8
    By jrprich in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 01-23-2009, 11:35 PM
  3. Trans fluid ? 50/50 mix atf+3 and atf+4
    By RED04DGCLE in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-21-2008, 10:28 PM
