Poll on front crank seal longevity
Results 1 to 10 of 14
Thread: Poll on front crank seal longevity
    Feb 2008
    FL
    701
    140
    have a leak of oil near crank seal, spitting around onto the blk plastic shroud in back of lower engine. Suspecting crank seal over oil pan seal, as it is spitting around to the shroud. Does this sound logical, and in how many miles could one expect this to occur? (99 voyager, 3.3L, 133,000miles)
    Thanks!
    Oct 2008
    Arizona, USA, and Elsewhere
    3,508
    Talking
    Quote Originally Posted by pippo View Post
    Thanks!
    There hasn't been any discussions (to my knowledge) on "Front" crank seals, however, we have discussed getting the "Rear" crank seal (Rear Main Seal) done whenever you have the tranny serviced (major tranny overhaul). I had mine done at 160kmiles (for a GEN1, that's the second tranny rebuild). When I rebuilt my 3.3L at 167kmiles, I replaced the front seal, as "PR" (I was there replacing the chain, so I also replaced the front seal).
    Still Going Strong
    Feb 2009
    Victoria BC Canada
    1,927
    Crankshaft seal
    Quote Originally Posted by AzTraveller View Post
    I have 117000 klm on my 3 ltr. 2000 Caravan and the front and rear seals are ok. touch wood!!!!!!
    Nov 2008
    DeSoto County, MS
    2,926
    All seals are fine on my '97 3.8 with 135,000 miles
    Apr 2008
    338
    hi to the best of my knowledge syn oil will keep the seals softer than regular oil -that may prevent the seals from getting brittle
    Aug 2007
    11
    Front seal replace
    I recently noticed an oil stain on the oil pan underneath the front crank seal on my '96 3.3L 120,000m. Prior to the leakage, oil level/usage was 1/4-1/3 qt between oil changes (5000 miles). Now, crankcase oil level drops considerably with freeway trips but around town miles still not much oil loss.
    I suspect oil pump housing seal, which of course is at the front of the engine. Have discussed the issue with my able mechanic and car will be in the shop soon to investigate further. Will keep you posted.
    Vince
    Jul 2011
    Phoenix, Arizona
    183
    I just noticed mine was leaking this morning while I was changing the serpentine belt. I have 253K miles, so I guess I can't complain. I plan on changing it very soon. I'll chime back in after I've replaced the seal
    Jul 2008
    Niles Il.
    10,101
    The leak isn't uncommon as the vehicles get up there in age. I would guess that an average lifespan of one is 175k miles. Some leak earlier, some never leak.
    '69 GTO drop top
    Jan 2011
    38
    Hey Pippo, I had posted an oil loss propblem on the 3.3/3.8 engine forum. I was going through a qt in 200 miles but couldn't see any profuse leakage, the tail pipe was clean and my coolant was clear. Only seepage I found was the front crankseal and the oil cooler. I just changed the front crankseal yesterday, and it was the easiest I have done. My factory manual referenced a special tool, which I found after I removed the pulley, would not have worked. The stealer said it would have cost over $200 plus parts and oil change to do the job. I have a 97 T&C with the 3.8 engine. The 3.3 is pretty much the same. I'm going to have to drive it for a while to see if the seal takes care of the high oil usage. If you are going to do this job your self, its pretty basic. Took me a couple hours after modifing my pulley puller to keep the bolt centered on the crankshaft.
    97 T&C 193K miles orig. trans
    Dave in VA.
    Sep 2011
    261
    Mazda can you post a pic of the mod you did on the pulley puller? Thanks
  1. Front crank seal leaking .....again!
    By pippo in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 09-02-2010, 12:57 PM
  2. removing front crank seal
    Last Post: 04-09-2010, 09:02 PM
  3. Front crank seal replacment
    By clayh in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 03-24-2010, 04:05 PM
  4. Front oil seal
    By greenlight in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 02-29-2008, 02:11 PM
  5. oil leak, front seal
    By gbeach in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 02-28-2008, 03:12 PM
