door panel removal on 2008 town and country
Results 1 to 10 of 19
Thread: door panel removal on 2008 town and country
    Jun 2008
    9
    Would like to upgrade the speakers in the front doors. Does anyone have the door panel removal instructions.
    Jul 2008
    Cottage Grove, MN
    66
    See attached
  4. The Following 2 Users Say Thank You to Kevins For This Useful Post:
    gsmagnum(07-10-2011), zthatzmanz28(10-04-2016)
  5. #3
    Jan 2010
    1
    Just as to not start a new thread...perhaps I'm an idiot, but how do you disengage the clips to pull the door panel off (it's a 2009)?
    I'm trying to replace the passenger side mirror as I decided to attack the garage while backing out & the door frame won. I have the replacement mirror & instructions but I figured the easiest part would be taking the panel off...apparently notsomuch, at least to me.
    Any tips for how to get this thing off? (I have the 2 screws out at least )
  6. Remove Advertisements
  7. #4
    Jun 2011
    1
    What the ****. Corrupted file!
  8. #5
    Apr 2007
    Minnesota
    4,206
    Quote Originally Posted by kuvasz2 View Post
    Corrupted file!
    The PDF opened just fine for me. It doesn't appear corrupted.
  9. #6
    Feb 2009
    Victoria BC Canada
    1,927
    Quote Originally Posted by gsmagnum View Post
    Me either, a window pops up and says its corupted or invalid.
  10. #7
    Jan 2010
    winterville, GA
    221
    Opens for me too, no problem.
    '87 Caravan LE 3.0, '91, '92, '93, '94 Grand Caravan LE 3.3
    '02 T&C Limited 3.8, '09 T&C Limited 4.0
  11. #8
    Oct 2011
    3
    The file is good. No problem for me. I need to replace the door latch.
  12. #9
    Jan 2007
    1,342
    232
    FWIW, won't open for me either, "invalid or corrupt file"
  13. #10
    Oct 2011
    3
    Try the file attached. It's the same as Kevins provided. I was also wondering what's the proper way to disengage the door panel clips. Can I use a rigid putt knife peel around the plastic panel, or I need some special tools? Any suggesiton will be appreciated.
  1. Door Panel Removal
    By hamiltonfighter in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 09-22-2010, 10:11 PM
  2. sliding door panel removal
    By gn300 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 05-04-2010, 04:52 PM
  3. door panel removal, power window repair
    By VANGO in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 04-15-2010, 06:21 PM
  4. door trim panel removal?
    By Noxzema in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 06-16-2009, 09:40 PM
  5. seat removal and door jam 1994 Chrysler Town and Country
    By Nixxle in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 01-29-2008, 12:53 AM
