How to disable the factory alarm
Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 48
Thread: How to disable the factory alarm
  1. #21
    Nov 2008
    DeSoto County, MS
    2,926
    Quote Originally Posted by jrprich View Post
    Maybe.......but my former 96 LXi was purchased new and it's alarm often went nuts
    Maybe these pictures will help:
    front driver and passenger door location.
    Rear Sliding door location:
    Here's a part name and number from Oreilly if that helps any:
    http://oreillyauto.com/EW3/ProductDe...&currentPage=0
    It's called a door jamb switch.
  3. #22
    Nov 2008
    166
    1
    in the mean time... have you considered pulling the fuse for the horn? If you can't disarm it, maybe you can just shut the damned thing up
  4. #23
    Jan 2009
    Hillsboro, Oregon
    894
    200
    Quote Originally Posted by k9sar View Post
    Thought of that, but what about the flashing lights and engine disable
    At present: 01 T&C Ltd. AWD 3.8
    Other cars:
    99 Corvette 08 Miata MX5
  6. #24
    Jan 2009
    Hillsboro, Oregon
    894
    200
    Quote Originally Posted by sideburns2009 View Post
    So replace the driver's door switch or all of them ?
    BTW, the Orilly link just goes to their homepage
    Other cars:
  7. #25
    Jan 2009
    Hillsboro, Oregon
    894
    200
    Looks like it is
    Niehoff Ignition Door Jamb Switch
    Part Number: DJ40211
    $8.29 each
    Other cars:
  8. #26
    Nov 2008
    DeSoto County, MS
    2,926
    Well it depends on which one could be bad. It could also be the hood switch(which I forgot to mention). I'm not sure how to test them individually honestly, unless you jumped the wires that go to it together to make a closed circuit(which i'm guessing is all the switch does) and see if the alarm still sets off for no reason.
  9. #27
    Oct 2008
    2,469
    43
    Would this switch also control the interior lights coming on? Could you turn your time to stay on after off to 0 and open the door and push the latch in manually to see if the lights go off one at at time? Just a thought, I don't really know and it surely can't be that simple.
    tcwagner1
    2005 T&C Ltd 3.8 108,000
    2000 Caravan 2.4l
    1965 Ply Valiant V8 85k
  10. #28
    Feb 2009
    Halifax Nova Scotia
    140
    I read somewhere(dont recall where) that car thieves were disabling the alarms in chrysler vehicles by doing something to the dome lights,either shorting them out or pulling the bulbs.My friends van was stolen and he mentioned something about the dome light. You might try pulling the bulbs to see if the alarm still sounds,or check the wiring to see if they are connected somehow.
    1999 Plymouth Grand Voyager Se AWD
    152,345 km 3.8 engine.
  11. #29
    Sep 2008
    76
    thats all odd mine hasent worked and im not sure what was done. being an ex chrysler fleet vehicle maybe they did something. i also know my fobs dont work and i wanted to fix the alarm but from all that i have read it sounds like its pretty problematic.
  12. #30
    Nov 2008
    DeSoto County, MS
    2,926
    Quote Originally Posted by tcwagner1 View Post
    tcwagner1
    Yes, it does control the lights coming on. That would also be a way to check them. Before I replaced mine, I could open my door and the lights would not come on, nor the door ajar light. I could wiggle the button around though and the lights and etc would come on. The driver side door switch went bad on my '94 T&C as well, with the same symptoms. I guess maybe because the drivers door is used more.
  1. How to disable factory security system?
    By aristidesrodriguez in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 02-01-2015, 03:01 PM
  2. Help! Can't disable vtss alarm!
    By andrewhgee in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 04-30-2013, 11:12 AM
  3. factory alarm
    By juan in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-07-2011, 12:34 AM
  4. Disable alarm? - van won't start T&C
    By PeterI in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 04-27-2008, 05:44 PM
  5. any tips for disabling factory alarm system??
    By Poffman in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 05-04-2005, 12:56 PM
