2009 Town & Country Fuel Economy
Page 1 of 12 1 2 3 11 ... LastLast
Results 1 to 10 of 111
Thread: 2009 Town & Country Fuel Economy
    Jan 2009
    17
    I have a brand new 2009 Chrysler Town & Country 3.8 engine I picked up i believe last sunday my question is i only have 180 miles on the van and my gas light came on already. I filled up the tank and it took 17 gallons of gas so i am doing the numbers and it seems like horrible fuel economy. I realize it is pretty much mostly street driving but 10 miles a gallon?? i am hoping i didn't buy the wrong vehicle here. Could it be just because the engine is new and has to break in? Should i bring it into the dealer and have them look it over?
    What are you guys seeing fuel wise in your 3.8's? ANy thoughts?
    Feb 2009
    44
    Quote Originally Posted by Rschrei518 View Post
    This van is a terrible gas pig, get used to it. Im getting around 15mpg combined Hwy City driving.
    Feb 2008
    San Jose, CA
    727
    My guess is that you didn't get a completely full tank of gas from the dealer. I'd wait until you at least start from a tank that you filled up yourself before computing your fuel economy. I have the 4.0L and I'm averaging 17-18 combined but mostly around town. There is no way you will be getting 10 MPG. Also, I would imagine that mileage will improve after the engine breaks in a little. Don't worry yet.
    2011 T & C Limited - White Gold/ - Dark Frost Beige/Medium Frost Beige
    Every option except Towing Package
    > 7,000 miles (had 1 on the odometer at delivery)
    Apr 2008
    New England, USA
    1,659
    20
    It'll get better.
    Check your tire pressure. Even a few pounds off can make a difference.
    2009 Dodge Grand Caravan SXT (3.8L), Light Sandstone Metallic, 125K miles
    2005 Volvo XC70, 160K miles
    Previous van: 2002 Chrysler T&C, eX (3.8L)
    Oct 2008
    Arizona, USA, and Elsewhere
    3,508
    Talking
    Welcome to the Forum
    Update your Location and Signature with full info on your vehicle. Get yourself a Haynes manual from your local auto store, if they have that year out, yet. It will help you with regular maintenance, that you're responsible for, as well as more major stuff, after the warranty expires.
    These engines, need about 1000 - 5000 miles on them to break them in and you will see an increase of mpg. By all means, start out with a full tank of gas, first. Monitor over a few fill-ups, not just your first tank / partial.
    Take advantage of ANY specials your dealer may have (free oil changes, free filter, free annual interior cleaning, etc).
    Definitely make sure your tire pressure is up to the tire mfr's recommendation. The dealer will recommend a pressure that will make your vehicle ride very smoothly, however, the tire mfr's spec (on the sidewall of the tire) will make sure you get max mpg, and max tire mileage, too. Yes, they are different.
    Still Going Strong
    Jan 2005
    Fayetteville, NC
    9,436
    Quote Originally Posted by AzTraveller View Post
    The PSI spec on the sidewall of the tire is NOT the tire manufacturer's recommended pressure for the tire. That's the maximum allowable inflation of the tire if you are at full tire load. As installed on a Chrysler minivan, the tire won't be at full load, and the tire is really over-inflated for the application. You MAY see a fuel mileage increase, but you also may not. There will be a ride penalty, and at the maximum inflation pressure, you may get an incorrect wear pattern. Call any tire manufacturer on the telephone and ask what they recommend for their tire and they will tell you that they don't recommend a tire pressure, and you should consult your owner's manual and/or the placard on the door jamb.
    The Chrysler dealer also does not recommend a tire pressure. All that is specified at the factory by Chrysler engineers.
    Oct 2008
    3,508
    Talking
    Quote Originally Posted by Jason View Post
    Jason, the side of my tires say something to the effect of "Max Cold Tire Pressure not to exceed 35PSI". I have done my best over the past 20 years with this van (35, if you include other vehicles) to keep them at that cold rating and have yet to have a tire wear out due to "over-inflation" (middle worn, with tread still on edges), instead, they have been evenly worn across the entire tread beyond the wear bars, to a point I feel they need to be replaced. The rear tires presently have nearly 90,000miles on them.
    YMMV
    Still Going Strong
    Mar 2008
    Southern WI
    381
    4
    YMMV
    I've always gone 2-3 psi over the door sticker figuring the the mfr was conservative toward a softer ride. However the tires on my latest van are listed at max-44 psi and I'm not going near that high.
    Sticker on the 2008 says 36 psi. 38 psi is working fine.
    Pat
    08 T&C Touring
    Previous vans:
    00 T&C 3.8
    95 GV 3.3
    89 Caravan 3.0
    Oct 2008
    3,508
    Talking
    Quote Originally Posted by monza View Post
    My Hyundai recommends 28 - 32. The Hancook tires say 44PSI (and so does their website). I was riding on the sidewall tread at 28PSI. I raised them to 40PSI, I now ride squarely on the tread, right to the edge, but not down it. I'm not rounding off the edges, anymore. I also get 34MPG, instead of 28MPG. The EPA rating is 28 - 32
    Funny how that works.
    Still Going Strong
    Jun 2008
    Oklahoma
    534
    3
    GUYS! Listen to what Jason is saying. There is a big difference in "recommended" tire pressure and "max" tire pressure. Anything over max is dangerous, so why would you initially inflate your tires to anyway near that.
    I live in Oklahoma where temperatures often exceed 100 degrees (f). If I inflate to 40 psi, and then hit the interstate on a 500 mile trip, it is very likely that I will at some point exceed the max (44 on my tires) - due to the tires heating up. I don't think going a pound or two over "recommended" is a problem. But running your tires at max is dangerous.
    I run my tires at the recommended (Chrysler) rate of 36psi. Safe way to go.
    2017 Chrysler Pacifica Limited 3.6L V6
    2004 Ford F150 SuperCrew Lariat 5.4L V8
  1. 2009 Town & country
    By Rschrei518 in forum 5th. Generation Chrysler Minivans: 2008-2016
    Last Post: 01-22-2016, 09:07 PM
  2. 2009 chrysler town & Country Touring Starting Problem
    Last Post: 09-08-2014, 04:38 AM
  3. 1994 Town And Country Fuel Gauge Problem (Digital)
    By Lord Plecostomus in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 09-25-2009, 09:54 PM
  4. 2006 Town & Country Fuel Pump
    By dkgunte in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-26-2008, 05:03 PM
  5. Fuel Economy
    By donandsandra in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 05-27-2007, 01:13 AM
