It appears that my A604 automatic transmission shift solenoid pack is leaking at the gasket with the transmission.
Trans fluid seems to pool behind the solenoid pack in a recess in the trans case and then leaks down onto the area of the trans pan and the front motor mount bracket......then to the floor.
I have degreased and pressure washed the area and the only place I can see trans fluid is behind the solenoid pack in a recess in the trans case. There does not seem to be any fluid coming out of the solenoid pack around it's front cover.
Since the trans shifts fine and was replaced by Chrysler in 07 I am considering just pulling the solenoid packand replacing just the gasket.
Thoughts ?
Are is circled in green on the pic
Thoughts ?
