Another rough idle thread
Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 45
Thread: Another rough idle thread
  1. #21
    Jan 2009
    Ohio
    595
    I have tested to see if the egr valve was getting power and I was getting around 14 volts.
  3. #22
    Jan 2008
    Nova Scotia, Canada
    16,697
    What's the year of that vehicle? If it has the older type EGR assembly, you should be able to make it work by putting a vacuum line directly to the valve itself and put a golf tee in the hose you disconnect. The problem occurs when the EGR valve allows too much exhaust gas into the intake. By putting a vacuum line directly to the valve, this should keep it closed so that no exhaust gas enters the intake. You may find the engine pinging at highway speeds though. I didn't when I did it on a 1995 that wanted to stumble and die. At least by doing this you can find out if it is the problem.
    The idea of allowing exhaust gas into the intake is to cool down combustion so less pollutants are emitted.
    If the Van is 2001 or newer, the EGR valve assembly is different. Apparently you can take these ones apart and clean them up. My 2002 was built without one, many were.
  4. #23
    Jan 2009
    Ohio
    595
    Quote Originally Posted by Jeepman View Post
    The van is a 2001 and it is a 3.3 if that matters. So you can clean these? The code I am getting is for the solenoid not the egr so I think the actual egr is good.
  6. #24
    Jan 2008
    Nova Scotia, Canada
    16,697
    Quote Originally Posted by Kscha41 View Post
    Solenoids were typical problems with the older models. Hope that solves your problem. I'm not familiar with any jimmying one might be able do with the newer ones. Anything to get the valve to close, would help.
    I believe somebody on here cleaned one up. I will look and if I find anything, let you know.
  7. #25
    Jan 2009
    Ohio
    595
    Well I finally took it to the local 5 star to have the problems diagnosed. They gave me five codes P0403, p1491, p0206, p0442, p0455. Now when I did the key dance I got p1491, p0403, p0206 and p1193. Now I can not find what p1193 means. I found a couple small cracks in a few hoses I am going to fix and the egr vacume hose is melted. Dodge told me that I need a new pcm, egr, radiator fan relay, vacume hoses and gave me a total of 1400 dollars They said the pcm will fix injector 6 and part of the radiator fan problem. The relay will fix the other. Oh they did some kind of recall while it was in and he said it was just a piece of tape. Well when I got home I noticed that the plastic peice that going around the radio and climate control was not in right. So I got home and took it apart and I noticed that they put some kind of tape on top of the radio. Well I put it together right. We should just part out the van. We went to a junk yard the other day looking for parts but no luck. They also told me that the egr was bad. If that was bad, wouldn't I get a code for this? Also why am I getting slighty different codes than the dealer?
    01 Dodge Grand Caravan (Sport) 3.3
    New tranny at 99,650 miles
    Currently 123,000 miles
  8. #26
    Jun 2008
    Oklahoma
    534
    3
    According to the book for my 2003, P1193 = Inlet Air Temp Sensor Voltage High.
    2017 Chrysler Pacifica Limited 3.6L V6
    2004 Ford F150 SuperCrew Lariat 5.4L V8
  9. #27
    Jan 2009
    Ohio
    595
    Quote Originally Posted by packerduf View Post
    My manual for my 01 gives P0113 for Inlet Air Temp Sensor Voltage High. I can not find P1193 in my manual.
  10. #28
    Jun 2008
    Oklahoma
    534
    3
    My book says:
    P0113 = Intake Air Temperature Sensor High
    I would have thought the codes would be common year to year, but maybe not. Anyone know?
  11. #29
    Jan 2009
    Ohio
    595
    My book says:
    Oh my bad, Intake and Inlet looked the same to me. Your right that P0113 = Intake Air Temperature Sensor High.
    I still can not find the other code in my book. Also thats wierd that dodge did not come up with that and as soon as I got it home I decided to do the key dance and I got slighty different codes and an additional code.
  12. #30
    Jan 2008
    Nova Scotia, Canada
    16,697
    Try this. http://answers.yahoo.com/question/in...2125556AAhHs2P
    Maybe Dodge left something loose when doing their check.
  1. Sometimes a very rough idle
    By Kscha41 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-12-2009, 08:28 PM
  2. Very rough idle
    By Bahnburner in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-06-2009, 06:39 AM
  3. Rough idle.
    By Gino45 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-22-2008, 07:40 PM
  4. rough idle
    By chaz amocat in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 03-24-2008, 02:04 PM
  5. Rough Idle
    By mrksstk in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 02-03-2006, 12:06 PM
