1992 Dodge Caravan Side door latch- lock problem
Results 1 to 5 of 5
Thread: 1992 Dodge Caravan Side door latch- lock problem
    Jan 2009
    1
    Unhappy 1992 Dodge Caravan Side door latch- lock problem
    This fall I bought a 1992 Dodge caravan.
    Body looks great for age and has 120,000 miles on it. Seems to run good.
    Have a problem with the side cargo door. I locked it at a store and tryed to unlock it again. Door won't open. The key turns in the lock but will not open with key or electronic lock.
    Would appreciate any suggestions.
    menospam50@yahoo.com
    Dec 2008
    1,985
    Either a plastic clip has broken and the linkage rod is now disconnected or else the latch mechanism itself is toast.
    Nov 2008
    Chicago, IL
    102
    Quote Originally Posted by menospam50@yahoo.com View Post
    as crazy as it sounds, start the van and then try the power lock.
    I had to do that this AM to unlock my sliding door. The solenoid for the lock is weak so it needs the extra power from the can being running to work right.
    Why would you lock your doors anyhow :scratch:
    94 Red Caravan SE sport 140k
    95 Grey Grand Caravan LE 150k
    94 Blue Caravan 130k Gone
    Jan 2008
    Winnipeg,Manitoba,Canada
    163
    Not sure about the GEN2's but the my GEN1, I had to open up the interior panel and adjust the lock rod, there was a bolt to loosen for adjustments. While I was in there i gave everything a spray down with white grease, and it works great now.
    1990 Grand LE 239000 km 3.3L A604
    1997 Lada Samara X94000 km 1.5L MPI
    1994 Mercury Topax 138000 km 2.3L
    GRAND TOTAL = $350.00
    Aug 2007
    33
    door latch problems
    see the post I put up today. disassembly of this thing is not bad, mine also just needed lube to work again.
    JD
  1. 06 Dodge Grand Caravan Sliding Door Problem
    By kevinandjenny7 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 08-13-2009, 10:05 PM
  2. Driver Side Door Lock Problemo
    By Plymouht2000 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 08-12-2009, 06:25 PM
  3. Sliding Door Latch Striker_ 1994 Dodge Caravan SE
    By dw8 in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 01-23-2008, 05:51 PM
  4. Driver side sliding door lock
    By aircongypsy in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 07-13-2007, 03:10 PM
  5. Rolling door latch-up problem
    By stancomm in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 02-08-2005, 06:45 AM
