Intermittent Oil Light - Oil Pressure Sensor?
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 37
Thread: Intermittent Oil Light - Oil Pressure Sensor?
    Aug 2007
    Detroit
    67
    1
    Wifey called today and said that the oil idiot light was coming on when she was on the brakes and/or turning. Went to a mechanic who said that the top end was sludgy and I had him do a flush. He got that done and it seemed to help for a while, but the light came back on later in the day. Took it back to him and he says that the oil pressure sensor/sending unit was leaking and that was likely the problem. Possibly shorting out the sensor.
    Anyone else believe that this could be the problem? What else could it be? Anyone seen this issue before? I did a search but all I could find was a discussion on synthetic v. non-synthetic oils.
    I would attempt a diagnosis myself but it's dern cold up here this week and I would rather pay a couple of bucks than work outside in sub-zero temps. Just want to make sure I'm not getting fleeced...
    - 2008 Town and Country Limited - 72k miles (ish)
    - 2004 Pontiac Vibe GT - 140k miles (ish)
    Oct 2008
    Arizona, USA, and Elsewhere
    3,508
    Lightbulb
    Chrysler/Dodge oil sensors are notorious for leaking ......
    It's cheap insurance to replace it.
    If you want, you can change your cluster (gauges) and have the one with the oil pressure gauge (different sensor). OR install an auxiliary pressure gauge somewhere, even if it's under the hood.
    Still Going Strong
    Aug 2007
    Detroit
    67
    1
    Leaking, yes... but shorting due to leak? And only at idle/when turning? That seems odd to me the more I think about it.
    Oct 2008
    3,508
    Quote Originally Posted by SomeYahoo View Post
    At idle and turning, sounds more like "low oil level". Have you checked the dipstick for OIL, lately?
    Replace the sensor, and check the dipstick for oil ?
    Sounds like you're 4 quarts low .......
    Still Going Strong
    Aug 2007
    Detroit
    67
    1
    Quote Originally Posted by AzTraveller View Post
    That's what I thought when I had her go to the mechanic/oil change place, but he did a full oil change and (obviously) topped it off. Still have the issue...
    Oct 2008
    3,508
    Yes, but DID YOU Check the level ?
    And if you say "Jiffy Lube", we'll ALL SCREAM at you. Too many members have had horror stories and lost engines, by going to "Jiffy Lube".
    PLEASE check your OIL level. Get the sensor replaced.
    Can't say it any simpler.
    Still Going Strong
    Aug 2007
    Detroit
    67
    1
    Wow... that post doesn't match your "mood" (mellow).
    I'm not at the van now, but I will check as soon as I get home. The flush/change was performed by and ASE certified mechanic (ex-dealer guy) at an independent shop that I trust. That said, I will check it as soon as I get home and report back.
    Is the sensor an easy swap (read: 15 min or less)? I can brave the temps for that long if it'll fix the issue...
    Apr 2007
    San Diego
    5,171
    Regardless of what the mechanic said, the sender is a common and cheap part to change in this situation. It's the cheapest part in the system. That said, the only way to know if you have an indication problem vs an oil starvation problem is to remove the sensor and connect a direct reading oil pressure gauge in it's place. This will tell you the true pressure in the system. If it then reads the correct pressure you start with a new sender. If it reads low then you have a bad pump or an oil channel or galley is blocked internal to the engine. It's a simple system with few options to repair.
    BTW - Why did the mechanic do a flush? Did he pull the valve covers and see the sludge or just surmise there was sludge. Flushes are a risky proposition.
    Oct 2008
    3,508
    Cool
    Quote Originally Posted by RIP View Post
    Regardless of what the mechanic said, the sender is a common and cheap part to change in this situation. It's the cheapest part in the system. That said, the only way to know if you have an indication problem vs an oil starvation problem is to remove the sensor and connect a direct reading oil pressure gauge in it's place. This will tell you the true pressure in the system. If it then reads the correct pressure you start with a new sender. If it reads low then you have a bad pump or an oil channel or galley is blocked internal to the engine. It's not rocket science.
    Thanks RIP,may wish to expound on the "risky part"
    Still Going Strong
    Aug 2007
    Detroit
    67
    1
    Okay... I'm going to brave the temps (have to snow blow anyway) and swap out the switch tonight. Looks easy enough, and like you all have said, it's cheap insurance.
    I'll report back.
  1. A/C pressure sensor
    By dgtc in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-10-2010, 12:12 AM
  2. Tire Pressure Monitoring Sensor Compatibility
    By rojpon74 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-12-2009, 02:29 AM
  3. Intermittent air bag light
    By Uncle Scrooge in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-24-2008, 07:55 AM
  4. broken oil pressure sensor
    By jetta_driver in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 01-24-2008, 01:47 AM
