replacement radio no sound
Results 1 to 4 of 4
Thread: replacement radio no sound
    Jun 2008
    Connecticut
    547
    1
    I replaced the stereo on my 2002 Chrysler T& Lxi equipped with Infiniti speakers.
    I used the Metra harnesses to properly connect the replacement radio harness to the factory one.
    The problem i have is the speakers do not work. It appears the Infiniti amp(s)
    are not receiving power. Anybody run into this before?
    There is a separate wire for the amp that ran to the ground of the radio.
    This I made sure was grounded as well.
    A good writeup on the Chrysler systems is here:
    http://www.wjjeeps.com/audio.htm
    Sep 2007
    Atlanta Georgia
    70
    it has something to do with the NBS name brand speaker relay in the fuse box under the hood it has to be turned on for the speakers to work the original radio turned it on via a message sent over the network if I remember right u will need to jump the relay or have it turn on when the radio is on.
    Owner Kevins Mobile Repair in Atlanta
    kkeller608@aol.com
    Jun 2008
    Connecticut
    547
    1
    Interesting,
    I found this, which may help.
    I know there is a lead for the radio for it, but there is nothing corresping to it on the harness.
    I did find an Infiniti wiring harness which indicates it should go to pin 1 on the C2 connector, which is the black one. I'll have to investigate that also.
    "The amp relay is in the Relay/Fuse box located under the hood. The amp relay is the one labeled NBS which stands for Name Brand Speakers.
    If you are trying to install an after market radio in a 2001 Chrysler Town and Country, you may notice that no sound comes from the speakers. This is because the single wire that is connected to the factory radio sends a signal to the Bus which tells the relay to turn on - powering the factory amp. I bypassed this by running a wire from the red Acc power wire on the radio to the relay. Connect the wire to pin number 87 on the relay. When standing in front of and facing the van, pin number 87 is the pin, on the NBS relay, which is closest to you and furtherst right"
    http://wiki.answers.com/Q/Where_is_t...r_Town_Country
    Jun 2008
    Connecticut
    547
    1
    got it working
    pin 87 was the 3rd pin on the connector. I believe it was purple/green.
    I used my multilmeter to corrrespond the relay socket with the pin below where the connector goes into.
    There is a grommet right above the pedals inside where you can push a wire through.
    It was pretty easy to do.
    Just make sure it connects to an accessory terminal so that it gets the proper voltage.
  1. Help Please!2002 T&C Installed after market GPS/Radio no sound!!
    By alina12901 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 03-11-2009, 07:15 PM
  2. VCR No sound 02 T&C
    By jra1100 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 03-09-2009, 01:15 AM
  3. Time display on radio screen when radio is off.
    By RCavanagh in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-06-2007, 10:57 PM
