Rear Cargo Organizer Installation Instructions
Results 1 to 10 of 15
Thread: Rear Cargo Organizer Installation Instructions
    May 2007
    2
    A friend sold me a factory option rear cargo organizer for my 2001 Town and Country. He bought it several years ago but never installed it.
    He provided all the parts but not the installation instructions. I've figured out how the lower two bolts attach but I am having a hard time figuring out where to place the two side supports that the upper shelf sits in when the organizer is raised.
    Does anyone have an idea where I could get the installation instructions?
    Failing that, could someone with this option provide a good photo of the upper side mounts so that I can get an idea where they should go?
    Thanks for any help you can provide.
    May 2006
    New Hampshire
    8,368
    Quote Originally Posted by dgdunlap View Post
    I can take a shot of ours and post a picture this weekend (possibly tomorrow, but I wouldn't bet on it).
    Apr 2008
    48
    Cargo Shelf
    Our van has the cargo shelf, the interior plastic trim pieces on either side of the hatch opening have big U shaped fittings to receive the rubber end bars, already molded in. Guess you'll have to scout out a van at a junk yard or buy right and left trim pieces from Chrysler? Ours came from the factory with the cargo shelf as listed on the original window sticker. They SHOULD have sold the trim/support pieces with the kit, one would think.
    The cargo shelf is AWESOME! It keeps all the junk we carry (3 kids) organized and out of the way, and we can fit a weeks groceries with no trouble. A work of genius! Just don't try to recline the seats with it up.
    Good luck to you.
    Charles
    Apr 2008
    48
    Installing It
    Sorry I skipped this- The two big screws go into the recessed fittings on the floor near the bumper, the rubber bar snaps into the fittings on the side trim (which you seem to be missing?). Real easy to install or remove with just the 2 screws. To fold down, fold all the tray dividers down, fold the tray front and back down, lift and usnap the bar, and lower it to the floor by the handle in the center.
    Jul 2008
    Under my vehicle
    122
    Cargo organizer installation
    I installed one of these a couple of years ago. My original van was totalled, and I grabbed the organizer from the van before it was hauled away. The replacement (used) van didn't have this option, so I was in the same boat on how to install.
    My way...
    Remove the trim side panels on each side of the door trim. On the back side of these panels, there are molded areas where the side supports need to go. You need a hole saw to drill through the plastic (don't know the size, but you can figure it out from the size support pieces).
    To secure the side supports, I installed T nuts, which I riveted into the metal door frame. I drilled holes for the rivets while the T-nuts were on the outside of the frame. As I recall, there were larger openings where I could fit the entire T-nut into the backside, and I used a string to pull the 'neck' of the T through a hole to the frontside. This gives a solid metal holding the T. The rivets are used to hold the T in place if you remove the support for some reason, but don't hole the weight of the support itself. A machine screw through he bracket into the T nut is all you need (put the trim piece back first).
    Just make sure the T nuts go on the backside of the metal frame; the rivets themselves aren't strong enough to hold the nut onto the front of the frame (ask me how I know!).
    If you don't have the supports, I bought them through the dealer (maybe $20 each or something ridiculous like that), but everything is color matched.
    I installed T Nuts to the floor (lip) area as well to provide a solid place for the floor screws to attach to.
    Hope my description makes sense...
    See pics from web images; my van is "in use" right now (meaning, my wife is out spending up a storm...) so I can't get any real pics.
  8. The Following User Says Thank You to sapp4l For This Useful Post:
    Joel_B(02-22-2014)
  9. #6
    Jun 2008
    Connecticut
    547
    1
    82206265 cargo tray install pdf instructions
    Wyckoff Chrysler has the instructions for the tray here:
    http://site.wyckoffchryslerparts.com...s/82206265.pdf
  10. #7
    May 2007
    2
    Thanks for the Cargo Organizer Help
    Combining these posts will let me figure it out. You guys were a huge help! Thanks a lot!
    Dan
  11. #8
    May 2004
    Ames, Iowa
    1,415
    8
    Is this a Grand Caravan feature only? I have a shorty and would like something like this.
    IAFarmer
    Current Rides
    02 Chrysler Voyager
    2012 Volkswagon Routan
    Ordered: 2015 Ford F-150 4x4
  12. #9
    Nov 2008
    47
    this seems pretty cool, i would love to install one of these!
  13. #10
    Apr 2008
    48
    Cargo Shelf
    If the area behind the seats is the same size as the longer vans, it should work. I know the shorter wb versions had less leg room in the 3rd row, but are they the same depth in the cargo area?
    If you have kids or a lot of junk it's worth $200 IMO. We tried a Chrysler/Mopar floor tray in our 3rd gen years ago, after a few months it ended up in the trash. This one works!
  1. 2001-2004 Cargo Organizer grey
    By 2004 T&C Ltd. in forum Items Wanted
    Last Post: 03-12-2010, 01:49 PM
  2. Gen 4 Cargo Organizer 2001-2004
    By BrooklynBridger in forum For Sale
    Last Post: 11-07-2009, 03:24 PM
  3. Cargo Organizer - 96-2000
    Last Post: 10-21-2009, 06:39 PM
  4. Starter Installation Instructions
    By bferrand in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 03-24-2008, 11:08 PM
  5. Cargo Organizer 4-Sale
    Last Post: 04-09-2007, 01:46 PM
