Results 1 to 10 of 15
Thread: Insanely DIM headlights on 1998 T&C?
Share/Bookmark
    Nov 2008
    New Castle, DE
    32
    I was wondering if anyone else has seemingly dim headlights on their minivan?
    There are times when I'm driving at night, and I say to myself "Holy crap! I don't have my headlights on!" and go to turn them on, only to find that they already are on.
    They barely light up the immediate 10 feet in front of my van.
    Are the bulbs burning out? Is there a semi-short in the electrical system? Is it the plastic covers over the lights? Do I need to change my bulbs to something brighter?
    Dave
    1998 Chrysler Town & Country LX LWB
    3.3L V6 158 hp, 168k miles (not all mine)
    Radio/tape/CD w/ Premium Sound
    currently for sale on Vehix
  2. #2
    Oct 2008
    Arizona, USA, and Elsewhere
    3,467
    Country
          AzTraveller's Country Flag is:  United States
    10
    Quote Originally Posted by dave_in_delaware View Post
    For starters, this evening, turn them on and go out and take a look at them. Do they actually look dim? OR is it the lens scratched up to the point they are so diffused, the light doesn't shine where it should. If they are actually dim, you probably have a bad ground, and or connection. Check you wiring and connectors. if it's the lens and they are diffused, there were comments on another thread about how to polish up the lenses using a little tooth paste, or polishing cream, and a rag to buff with. there are also some kits out with very fine grit wet sanding paper and instructions on how to polish them up.
    1990 Plymouth Grand Voyager LE 3.3L LWB-- 198k miles and counting ......
    318,650.1 kilometers, for you metric buffs ......
    Horse Power = How Fast You Hit the Wall .....
    Torque = How Much of the Wall, You Take With You.
  3. #3
    Nov 2008
    New Castle, DE
    32
    Thanks AzTraveller! I'll "inspect" them tonight and see what's what.
    Dave
  4. #4
    Nov 2008
    3
    sand paper fix for dim headlights
    dave, I have a 1996 grand voyager that had the same problem. thought I was going blind. Its called headlight cataracks ( lens dulling) I did a three step process that FIXED the problem by 1000%. step 1. dry sand the lenses with course aluminum oxide sanding block sanding horizontally on lenses from top to bottom. step 2. wet sand with a rubber sanding block and 1500 grit wet sand paper. rinse off lenses and repeat step 2 until lenses look 90% to new lens look. step3. use plastic lens polish with a clean dry cloth or purchase a small buffing wheel and a cordless drill ( i used drill and had better results than hand rubbing) and viola!!! new lenses to improved safe night driving. sand block and wet paper and buffing wheel buy at home depot/lowes. polish buy at auto zone/advance auto. total cost approx. $20.00 total time to fix 30 min. at most. this is by far an easy DIY verses buying new lenses ($149.00 per lens). hope this helps you out. It did for me.
  5. #5
    Jan 2008
    Halifax Nova Scotia
    1,224
    Hi Dave, my lenses on my 94 were so bad that maybe only 40% of the light from the bulb was penatrating through. I was driving almost blind @ night.After I did a really good lens cleaning (compond & very fine grit paper) I could see amazingly.No need for new bulbs
    1994 Dodge Caravan SE 3.0L 448,000km and counting
    1978 V8 AMC Pacer DL(sold my 16 yr love affair)
    1974 AMC Gremlin
  6. #6
    Jan 2008
    Nova Scotia, Canada
    7,073
    7
    There's a lot of criticism about the brighness of the Generation 3 headlights at the best of times. With the oxidation that occurs on the lens, they can get fairly yellow/dim.
    For starters take some toothpaste with whitener in it - put it on, let it dry, and buff it off OR use some scratch doctor product (Nu Finish Scratch Doctor, for example - clear coat scratch remover - removes surface scratches, swirl marks, haze) and see if that doesn't make a tremendous difference.
    The above are basically buffing compounds. My Son uses toothpaste on his 1995 Caravan with great success. Two Guys Garage apparently did the toothpast cleaning on Spike for all to see: http://www.dieselplace.com/forum/sho...=261223&page=2
    Here's some relevant information on application of the various compounds and polishes, including toothpaste:
    http://www.carspace.com/guides/Healing-Hazy-Headlamps
    HOWEVER
    There is another school of thought, and it makes sense, such as found at http://reviews.ebay.com/Cleaning-Res...00000000945494
    Here's the Pittman video - looks so simple.
    http://www.youtube.com/watch?v=bYJlIqFz6sM
    Next, replace your bulbs with those high intensity types, that blind everybody coming toward you, and you are on your way.
    2002 GC Sport - 3.3L - 229,600 kms
    2003 Jeep TJ Sport - 4.0L - 211,300 kms
  7. #7
    Jan 2008
    Halifax Nova Scotia
    1,224
    Product I have used is called BlueMagic Headlight Lens Restorer.This product was also Two Guys Garage.
    1974 AMC Gremlin
  8. #8
    Jan 2004
    DC area
    227
    Quote Originally Posted by Jeepman View Post
    Is that stuff for real? Will it really work that well? We used one of those kits (permatex, I think) from the Auto Parts store and it took alot of effort, and the results were not as good as desired.
    !We put Silverstar Ultra's in when the light went out and it has made a huge difference
    Scott
    2005 Dodge Grand Caravan SXT
    3.8L-V6, 76K miles.
    Previously had:
    *1999 Plymouth Grand Voyager SE 3.3L-V6 FFV, 141K miles.
    *1999 Braun Entervan III (Dodge Grand Caravan modified for wheelchair users) - 65k miles 3.3L V6 FFV
    *1988 Plymouth Grand Voyager SE 3.0 V6 with 3 spd tranny -168K miles on it.
  9. #9
    Jan 2008
    Nova Scotia, Canada
    7,073
    7
    Quote Originally Posted by dkf747 View Post
    My sense is that the Pittman stuff will work fine for the oxidation but may not for the pitting and scatches experienced in the real world of road salt and sand on the highways (equivalent to sandblasting).
    Anybody out there with experience with the Pittman fix?
    Here's some opinions on Yahoo: http://answers.yahoo.com/question/?q...9215351AAKHqRY
  10. #10
    Nov 2008
    Northern VA
    144
    Country
          biometrics's Country Flag is:  United States
    On Ebay for less than $85.00 shipping included! I am sure they are not OEM, but they have to be better than home-polished lenses...
    1997 97 Chrysler Town & Country Grand Headlight Pair
    FREE SHIPPING - Brand New Certified Quality Part -Boxed
    http://cgi.ebay.com/ebaymotors/1997-...Q5fAccessories
  • You may not post replies
