Blower motor resistor removal?
Results 1 to 10 of 19
Thread: Blower motor resistor removal?
    Sep 2008
    Ohio
    109
    It appears the resistor is secured from the inside of the firewall, I removed the glove box but still can't get to it. Any help will be appreciated. BTW it's a 96 caravan 3.0.
    Jan 2008
    Nova Scotia, Canada
    16,565
    Quote Originally Posted by Doug_C View Post
    Take a look at ths Thread, Post #2: http://forum.chryslerminivan.net/showthread.php?t=9330
    It will lead you to some pictures.
    Sep 2008
    Guatemala
    38
    I just changed mine its also a 3.0 but 2000 voyager, mine was burnt, had to pull it hard since the little metal things where bent had to pull it hard from the engine compartment, however mine had a bit burnt the connector but I cleaned it and it worked, if gets on fire Ill just collect the insurance ajajajajaa
    Jan 2008
    Nova Scotia, Canada
    16,565
    Quote Originally Posted by Jeepman View Post
    OOOps, wrong Thread, Wrong Generation. Try Post #18 of this thread instead: http://forum.chryslerminivan.net/sho...esistor&page=2
    3rd Generation: under the hood on the fire wall near motor location. The following Thread, and Posts #9 & #11 in particular, tells where the resistor is located on a 3rd Generation and how to replace it. http://forum.chryslerminivan.net/showthread.php?t=9851
    May as well go to this one first. It has the pictures: http://www.automotiveforums.com/vbul...d.php?t=340871
    Sep 2008
    Ohio
    109
    Thanks for the replies, I finally figured it out. Took a screw driver and pried it right out. I thought it was screwed in but it is held in by clips.
    Sep 2008
    Ohio
    109
    Quote Originally Posted by HermanMasaya View Post
    Funny, mine had a little burnt spot on the blue plastic piece on connector also. Had lots of rust too, when the new one comes in tomorrow I might try too seal it up alittle better.
    Apr 2008
    338
    Hi just changed my resistor on a 1999 chrysler t&c --just yank it out -any way you can -held in with clips-use a screw driver to pry it out from the shock tower side-do not worry about damaging the clips-you have new ones on the new resistor- do not pull on the wiring -but do pull the wiring and the resistor out together-then separate the plug and the wire harness- the wire harness may need to be replaced-but do inspect it for wear-or rust
    Jul 2005
    NJ
    1,571
    6
    To answer the question in its original form, there actually is a way to access the spring tabs from behind the firewall. The resistor sits inside HVAC housing, and can be reached through the recirculation door opening after removing the blower motor cover (but not the motor, 4 screws). The door has to be in the "fresh air" position. This may even be less painful then the usual way.
    Apr 2008
    338
    HI ALVIN PLEASE INDICATE THE YEAR VAN YOU ARE WORKING ON-AS MY 1999 CHRYSLER t&c-HAD NO ACCESS FROM BEHIND THE GLOVE BOX-AS OTHER POSTS HAVE ALSO INDICATED YOU WOULD FIND-ALWAYS INCLUDE BASIC INFO-YEAR-MODEL-ETC -IN THESE POSTS-SO OTHERS CAN BE OF MORE HELP WITH A GIVEN SUBJECT
    Jul 2005
    NJ
    1,571
    6
    Mine is a 1999 model so it's the right forum.
    The cover is not behind the glove box but on the bottom of the blower housing, facing down. The glove box can stay in place (closed) for this procedure. It's the cover you would have to remove for replacing the blower motor, but taking it off also allows to reach through the air intake towards the firewall side of the housing.
    There's lots of room to work, just use a good light.
  1. Repair: Blower Motor Resistor Module
    By Chrysler1924 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 09-01-2010, 10:35 PM
  2. Blower motor resistor location in '96 Caravan
    By donevan in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-20-2010, 05:20 PM
  3. Front blower motor resistor block
    By trcar54 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 02-17-2010, 07:14 PM
  4. Van won't start after trying to replace blower motor resistor
    By ddma99 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-09-2009, 06:56 PM
  5. blower motor/resistor
    By CatrinaO in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 11-04-2008, 09:51 PM
