Lug Nuts - Torque
Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: Lug Nuts - Torque
  1. #11
    Oct 2008
    Arizona, USA, and Elsewhere
    3,508
    Quote Originally Posted by DaveInColumbus View Post
    For most applications such as steel wheels on vehicles whose rotors are proven not to warp (such as my 'Scort) I don't know why either is important. My wheels aren't going to fall off and there are no discernable effects to uneven torquing, of which there is plenty when using an impact wrench. In other words, I don't see potential for damage or failure in most cases.
    I tend to be more careful with alloys than steel wheels. I've read about some wheel cracking due to use of an impact gun and I figure that's not really worth. Since most of the vehicles I've owned have steel wheels, my impact gun has sufficed for those cars.
    I actually had someone with an impact wrench "stretch" the threads on several lugs. When I later removed the lugs to change a tire, I found the threads "pulled" on the studs. You could actually see where the nut stopped on the threads. I had them replace every one of the studs.
    Another time I had some impact wrench happy tech cross thread a couple of lugs. What a time getting them off .....
    I'll stick with my long handled breaker bar.
    Still Going Strong
  3. #12
    Jan 2008
    Nova Scotia, Canada
    16,451
    Quote Originally Posted by Jeepman View Post
    What's the torque specs for your lug nuts? 90 ft. lbs., 100 ft. lbs.?
    The difference between the two torques is about 1/16" on the circumference of your socket. Not much, the difference between 80 ft. lbs. and 100 ft. lbs. is less than 1/8".
    I was expecting a lot more movement for those increments of torque. I did these comparisons today when putting new rotors on the front of my Van.
    I would be interested in knowing what others are getting for rotation at the socket starting at 80 ft. lbs. as the base torque, to compare with my 1/16" at 90 ft. lbs. and 1/8" at 100 ft. lbs. Good way to compare torque wrenches.
  4. #13
    Dec 2007
    south west ohio
    489
    12
    anybody put anti sieze on the lugs like i do? i know you are suppose to reduce the torque with anti seize, but i don't know how much.
    2001 Short Caravan 3.3L
  6. #14
    Jan 2008
    Nova Scotia, Canada
    16,451
    Quote Originally Posted by x99j View Post
    I was going to do a comparison of not lubricated verus lubricated to see what the rotational difference is .... still on the agenda .... one of these days.
    Might be best to torque to 90 ft. lbs. rather than 100 ft. lbs., if using a lubricant.
  7. #15
    Feb 2008
    Columbus, OH
    1,079
    I use regular grease. Like Brylcreem, "A little dab'll do ya." I put it on all the lugs I worked with last Sunday.
    Caraturd3: 2016 DGC AVP, 4.5k miles.
    Caraturd: 2000 DGC Sport, 126k. My first minivan, with badly rusting strut towers that ended its life prematurely. Unceremoniously junked on 7/23/2013.
    Caraturd2: 2006 DGC base, 65k. Traded on 5/31/2016.
    2015 Ford Focus ST3
    2003 Ford Focus ZX5, 5-spd. My winter car because the ST doesn't have winter tires.
  8. #16
    Feb 2008
    Columbus, OH
    1,079
    Quote Originally Posted by AzTraveller View Post
    ... I had them replace every one of the studs.
    Which, ironically, is done by pulling the lug stud through the hole with a nut.
    2015 Ford Focus ST3
  9. #17
    Dec 2004
    Virginia
    4,029
    ...My wheels aren't going to fall off...
    You sure about that? It's an Escort after all (just kidding--note this is coming from someone who has owned three Escorts)
    Michael
    Centreville, VA
    Currently driving:
    Former owner of:
    Other vehicles:
  10. #18
    Oct 2008
    3,508
    I've had no problem "manually" pulling new studs in place with a long handled ratchet. I can "feel" when they've bottomed out that way.
    Still Going Strong
  11. #19
    Apr 2006
    Dearborn, MI
    2,584
    Well the shop I worked at we used the Impact to zip the lugs on and off, but we gave the lugs a couple threads first to make sure we weren't cross threading them. Personally I don't like using a straight impact to put the lugs on, especially when you got one with over 600 ft-lbs of torque(overkill nah). I'd prefer if I had to use an impact to at least have some torque sticks to stop the impact from gunning the lugs down at a certain torque spec, i.e. 85 ft-lbs, 95 ft-lbs, 100 ft-lbs. Honestly on my own PT I don't use a torque wrench. I just get it tight, and then a little more, and since I'm usually the only one to take the wheels on my PT on and off I know they won't be over torqued, or under torqued.
    One of my friends actually had a wheel on his Camaro that someone had torqued down so tight, that while he was driving down the freeway, the wheel broke off... or at least thats what he says
    Im 26 and my parents own a 2014 Grand Caravan R/T (3.6l, 22k miles) 2007 Dodge Caliber SXT (1.8l 87k miles 5spd), a 2001 Chrysler PT Cruiser ((which is mine) 2.4l 125k miles 41TE), and a 2000 Ford Mustang base (3.8l, 4 spd auto 30k miles)
  12. #20
    Jan 2008
    Nova Scotia, Canada
    16,451
    Quote Originally Posted by Benny View Post
    I can give names of people that have had their wheels come off because the nuts weren't tightened properly.
    A fellow employee was one and I witnessed the incident on the way to work some years back.
    I also know a Lady that had her wheel over torqued at a Dealership and managed to stop the vehicle before the wheel came off. The holes were badly chewed.
    After having someone else, such as tire service centers, work on your vehicle, get your torque wrench out and re-torque every lug nut. There's a reason for them saying to return and have the nuts checked for torque after a 100 kms. They don't even trust themselves.
    I have never had a nut loosen up that was torqued up properly. Usually they get harder to remove with time.
    As to the studs, they can take a higher torque than the 100 ft. lbs. so the concern really is about damage to the rim holes.
    Some torque ratings for bolts: http://dodgeram.org/tech/specs/bolts/SAE_bolts.html
    This site is interesting. Click on Grade 8, 1/2" and fine thread:
    http://www.efunda.com/designstandard...que.cfm#Answer
    Here's what Discount Tire says about torque. They seem to have their own specs:
    http://www.discounttiredirect.com/di...heelTorque.jsp
  1. Nuts!!!
    By amelnik in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 11-23-2009, 10:27 PM
  2. bcm is nuts or bad pcm
    By gami892 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 09-15-2009, 02:13 AM
  3. To all car nuts...
    By shipo in forum The Fireplace
    Last Post: 09-24-2007, 01:15 PM
  4. Lug Nuts
    By mom2537 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 01-24-2007, 08:50 AM
  5. Car Nuts
    By DSMLVR in forum The Fireplace
    Last Post: 12-23-2004, 12:35 PM
