How to "re-flash a transmission
Results 1 to 9 of 9
Thread: How to "re-flash a transmission
    Feb 2007
    1
    Can an individual "re-flash" the transmission after changing the transmission fluid or does a dealer have to do this? How is the "re-flashing" done?
    Jan 2006
    Katy, Republic of Texas
    1,105
    The transmission continiously "learns" your driving style.
    Some people complain of harsh or sloppy shifts after a fluid change, and a dealer can "reset" the transmission control module (TCM) parameters to what they were from the factory and let it re-learn from new.
    I am not sure if just disconnecting the battery does this or not.
    Just a note: If you have five dollars and Chuck Norris has five dollars, Chuck Norris has more than you.
    Dec 2004
    Virginia
    4,029
    There are also periodic updates to the module. Simply disconnecting the battery does not perform the updates. Often "Flashing the TCM" means providing an update.
    Michael
    Centreville, VA
    Currently driving:
    Former owner of:
    Other vehicles:
    Apr 2008
    New England, USA
    1,659
    20
    I also do not think that disconnecting the battery resets the parameters to the default (factory) settings. This seems to hold true anecdotally at least with my van -- I never notice a difference in the shifting after disconnecting the battery. Also, if the memory is indeed "flash" memory, it does not get cleared when powered down.
    2009 Dodge Grand Caravan SXT (3.8L), Light Sandstone Metallic, 125K miles
    2005 Volvo XC70, 160K miles
    Previous van: 2002 Chrysler T&C, eX (3.8L)
    May 2004
    Ames, Iowa
    1,415
    8
    It really needs to be a dealer thing. IT may take weeks for your tranny to "relearn" how to shift. How much more than $90 worth of damage are you doing in the meantime?
    IAFarmer
    Current Rides
    02 Chrysler Voyager
    2012 Volkswagon Routan
    Ordered: 2015 Ford F-150 4x4
    Jan 2007
    Colorado Springs, CO
    127
    Good point. I have been wondering about this myself. After reading that, it seems silly to not have it done.
    100 bucks and an hour might save you a few thousand and a week down the road. It's a no brainer.
    When troubleshooting, always assume the simplest cause first!
    '02 Chrysler Voyager
    Short Wheel Base
    2.4L 3 Speed
    102,000 Miles
    Sep 2008
    Canada
    405
    You don't need to reset your trans controller after changing the fluid.
    The trans controller adapts based on internal wear and driving style.
    Just changing the fluid isn't enough to throw things out of whack.
    As long as you used the proper fluid and filter and have the fluid at the proper level your good to go.
    You only swapped out 1/4 to 1/3 of the fluid anyway.
    2003 GRAND CARAVAN SPORT
    1997 RAM 1500 SPORT 4x4
    2003 ALERO
    Jun 2007
    Stuck in NJ Traffic
    1,269
    Changing the fluid CAN result in the rough downshift, even with all MOPAR fluids and filters. IAFarmer and I are the poster children for that.
    You will do no damage with the rough shifts (though, it IS very disconcerting) until the TCM "learns" to shift with the new fluid. Is it worth $100 to eliminate? You be the judge....
    We had the rough-downshift after fluid & filter at 62K miles. Took about three weeks (1000 miles) to smooth out again. We made an appt for the re-flash, but by the time the 2-week waiting time came up, the trans was 90% better so we cancelled it.
    Now, a year later, all is still well....
    Atwell "Buff" Haines
    Northern NJ
    2002 Grand Caravan ES "Extra Special"...
    Blue
    3.8L, Touring Suspension, 17" Alloys, and Autostick
    Sep 2008
    Canada
    405
    Interesting...
    I've done hundreds of trans services on these transmissions and I can't say I've ever had a customer complain of a rough shift after a simple trans service.
    2003 ALERO
  1. Transmission re-flash
    By dgtc in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-09-2010, 08:06 PM
  2. 2001 T&C LXI 3.8L Transmission stuck in "L"
    By 2001LXI in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 08-23-2010, 10:09 PM
  3. Transmission "bump" while downshifting
    By tylerfeltz in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 07-23-2010, 09:00 PM
  4. FUNKY transmission problems after dealer "fixed"
    By bigreddog in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 04-09-2010, 04:08 PM
  5. Damaged Transmission? Dealer Says "Nope, it's fine."
    By Chrysler1924 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-31-2008, 03:27 PM
