Thermostat 2004 Caravan
Results 1 to 10 of 12
Thread: Thermostat 2004 Caravan
    Feb 2007
    7
    Hi everyone,
    Sorry if this has been asked before, I looked and couldn't find anything. Provide link please if this is already posted.
    I am having a heat issue on my 04 Caravan 3.3L. It's getting cold here and I have on sporadic heat coming from the vents. The heat gauge goes to about half then I get a burst of heat then the needle drops and then I get nothing. From what I can gather this is a thermostat issue. Is replacing a thermostat a DIY thing? I called around and they want $150 to replace this thing. From what I can tell this looks to maybe be a 10 minute job. Am I totally wrong? Should I just pay the $150. If not, anyone have a guide? Also, I hear there's TWO thermostats in my van, any ideas which needs to be replaced?
    Thanks for any help you can provide.
    Jan 2008
    Nova Scotia, Canada
    16,539
    Quote Originally Posted by rlegault View Post
    Hi everyone,
    Better check your coolant level (in the radiator and the overflow / reservoir tank). Sounds like your coolant level is down and air in the system is causing your problems. As to adding more coolant, it depends on what color is in there now. If orangeish, it's HOAT like it should be, go with Zerex G-05 50/50 mix. If green, then what coolant is it - probably 2 year life regular glycol?
    Jun 2004
    rochester,ny
    748
    7
    heat
    All chrysler coolant is orange hoat since like 2001 so only use that to refill or the zerex equivalent , do not mix with green antifreeze if low. when engine is completely cold look at the coolant recovery tank , level should be midway between the min and max marks on the bottle.
    2014 Dodge Grand Caravan AVP
    Deep Cherry Red
    45000 miles
    2008 Isuzu Ascender
    Midnight Metallic
    105500 miles
    Feb 2007
    7
    I feel like such a tool!
    You were totally right. There was ZERO coolant in the overflow and about 2 to 3 inches down in the RAD. I bought some or the orange stuff. Dex cool in this case. only stuff I could find at Canadian Tire that was Orange (well they had their brand also). I still can't believe I didn't open the hood and look before posting.
    Thank you everyone for your help...BTW I have tons of heat now.
    Jan 2008
    Nova Scotia, Canada
    16,539
    Oooops. Mixing Dex-Cool (OAT) with G-05 (HOAT) may not be good. They have even managed to complicate coolants.
    http://www.valvoline.com/zerex/
    Sep 2008
    Canada
    405
    Here is an interesting article describing the various types of Coolant/Antifreeze.
    http://www.filtercouncil.org/techdata/tsbs/05-2.html
    here is a sample
    Quote:
    Hybrid Organic Acid Technology (HOAT) is a combination of IAT and OAT with nitrites added. This makes HOAT suitable for use in both light duty and heavy duty systems. Currently, two manufacturers are using HOAT for their vehicles. Daimler/Chrysler's version is dyed orange and contains 10% recycled antifreeze. Ford Motor Company's version is dyed yellow and does not contain any recycled antifreeze. Both of these HOAT antifreezes use the marketing designator of GO-5. They are compatible with each other but mixing them with IAT or OAT is not recommended. The normal HOAT antifreeze service life is 5 years or 150,000 miles (250,000 km).
    End Quote
    Based on this I think you are probably OK to top up with a little Dexcool (OAT)
    coolant but be careful in the future.
    2003 GRAND CARAVAN SPORT
    1997 RAM 1500 SPORT 4x4
    2003 ALERO
    Jun 2004
    rochester,ny
    748
    7
    coolant
    Don't put dexcool in , thats GM coolant . If you did you should think about getting it flushed at the dealer . I would also have them check around ,in a properly operating system you should not lose any coolant . Possible water pump going and leaking out that ???
    Deep Cherry Red
    45000 miles
    2008 Isuzu Ascender
    Midnight Metallic
    105500 miles
    Jan 2008
    Nova Scotia, Canada
    16,539
    Quote Originally Posted by vipergg View Post
    I recently checked a 2005 - 3.3 for a Friend. It was not giving out any heat from the heater. Sure enough, the coolant level was down. Why ... I still don't know. Aded some G-05 50/50 (the yellow Ford type was available at Wal-Mart) and it seemed to be holding for the next couple of days. I suspect a leak somewhere though and must check the level again and add some stop leak if it is down / down enough.
    Probably best to do a pressure test though and verify where the leak, if any, is.
    Dec 2004
    Virginia
    4,029
    Quote Originally Posted by Jeepman View Post
    I don't think the yellow Ford type is true HOAT, is it?
    Michael
    Centreville, VA
    Currently driving:
    Former owner of:
    Other vehicles:
    Jan 2007
    Colorado Springs, CO
    127
    There it is right there. Low coolant level is only a symptom of a bigger problem. Find the leak and fix it. Neglecting the cooling system is a huge mistake!
    When troubleshooting, always assume the simplest cause first!
    '02 Chrysler Voyager
    Short Wheel Base
    2.4L 3 Speed
    102,000 Miles
  1. 2004 Dodge Caravan
    By rlegault in forum Introduce Yourself and Your Minivan
    Last Post: 04-08-2008, 09:09 AM
  2. Ad for the 2004 Grand Caravan
    By DSMLVR in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 04-30-2004, 05:43 PM
  3. 2004 Caravan SXT
    By AMD Rules in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 11-21-2003, 10:10 AM
