Is there a way to check the gas cap?
Results 1 to 8 of 8
Thread: Is there a way to check the gas cap?
    Sep 2006
    515
    2
    I'm getting a check engine light on my '01 (P0441 code...evap emission control system purge flow fault). Is there a way to check the gas cap? It looks fine, but I could swear the last time I shut the vehicle down and opened the fuel door, I heard a slight air leak sound.
    2014 Chrysler Town & Country 30th Anniversary Edition
    2007 Acura MDX
    1996 Mustang Cobra
    1995 Lincoln Mark VIII
    Apr 2007
    San Diego
    5,209
    If your gas cap has a fault you may see a P0456 code. Here's the causes and solutions for the P0441 code: http://www.obd-codes.com/p0441
    If you insist on checking the cap ask any smog test shop to connect it to their cap tester. It would take them 2 minutes.
    Sep 2006
    515
    2
    I'll answer my own post. I just swapped the one on the '01 with the one on the '05. I'll post the results.
    2007 Acura MDX
    1996 Mustang Cobra
    Jun 2004
    rochester,ny
    736
    7
    gas cap
    Let me know if you find an answer , getting the same code which just started today .
    Just started getting a check engine light on a 2004 T&C with the 3.3 liter engine . Doing the famous keydance I get a p0441 dtc . Any known common easy to fix issues that might cause this ? Will a bad gas cap cause this or are we looking at something more substantial ? The car is running fine at this point other than the MIL . A search reveals the following info but that is a pretty wide list of things it could be , probably stuck going to the dealer. Saw no lines or hoses that looked out of place.
    A code P0441 could mean one or more of the following has happened:
    * Bad vacuum switch
    * Broken or damaged EVAP line or canister
    * Open in PCM purge command circuit
    * Open or short in Voltage feed circuit to Purge Solenoid
    * Faulty purge solenoid
    * Restriction in EVAP solenoid, line or canister
    * Corrosion or resistance in purge connector
    * Bad PCM
    Possible Solutions
    With a P0441 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try:
    * Common Chrysler fix - Replace Leak Detection Pump / LDP
    * Repair damaged EVAP lines or canister
    * Repair open or short in voltage feed circuit to Purge Solenoid
    * Repair open in PCM purge command circuit
    * Replace purge Solenoid
    * Replace vacuum switch
    * Repair restriction in Evap line or canister or soleniod
    * Repair resistance in purge connector
    * Replace PCM
    2014 Dodge Grand Caravan AVP
    Deep Cherry Red
    45000 miles
    2008 Isuzu Ascender
    Midnight Metallic
    105500 miles
    Jan 2008
    Nova Scotia, Canada
    16,449
    Did P1684 show up as well by any chance?
    Sep 2006
    515
    2
    Quote Originally Posted by Jeepman View Post
    No other codes.
    2007 Acura MDX
    1996 Mustang Cobra
    Jan 2008
    Nova Scotia, Canada
    16,449
    Quote Originally Posted by BlackOnBlackCobra96 View Post
    No other codes.
    P0441 EVAP - Incorrect purge flow per the 2003 thru 2006 Haynes Manual. EVAP purge flow moniter failure - Insufficient or excessie vapour flow during EVAP system operation per 1996 trru 2002 Haynes Manual.
    Just in case it is a glitch, I would disconnect the negative battery terminal for about 10 minutes, reconnect, and see if ithe code returns. I had a P0456 (EVAP small leak) show up during the Summer, and disconnecting / reconnecting the battery cleared it, without return. Worth a try. When I check my vehicle today, it says donE, that's it.
    Feb 2007
    Southwest Ohio
    353
    bob96:
    The fact that you heard the hiss when removing the cap means it is still doing its job. When the cap died on my 01 Durango, the hiss was no longer present.
    The good news is that a spanking new one at the dealer is a whopping $14.
    Don
    05 Linen Gold Pearl Dodge Grand Caravan SXT 3.8L (hers)
    04 Flame Red Hemi 5.7L Dodge Durango SLT
    (Mine)
  1. Ignition Key Check for Check Engine Codes
    By bluebgone in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-28-2007, 07:28 PM
  2. how do you do O.B.D. check
    By wolly1 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 11-03-2007, 06:20 AM
  3. VIN check
    By vanlover2 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 03-23-2004, 10:15 AM
  4. Check this out...
    By tarheel in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 03-17-2004, 10:11 PM
  5. CHECK THIS OUT...
    By redriderbob in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 01-21-2004, 09:19 PM
