Van GV 1997 Stop running suddenly in highway
Results 1 to 10 of 15
Thread: Van GV 1997 Stop running suddenly in highway
    Dec 2007
    9
    Hey guys,
    I was getting into the ramp to get into a very bussy hwy in Toronto (400) and suddenly my van dyes on me, what scary moment, no power stering, I have to react quickly and I manage to start it again while runing and it did start and the engine light came on, this was saturday night, and then now the light is off and the van is running fine, also I noticed that the fuel gauge was going up and down all night ( my car was with a full tank) but the needle just start going to empty and the beeping alarm when is low on fuel was on and off. now this fuel gauge is ok. Please can anyone tell me what is going on ? I left my van parked since may and I just start using it again last week, could be because of that? I have 205.000 Km. I just did the emission and was perfect, it passed it.
    Thanks for your comments.
    IBM
    Jun 2008
    387
    Those were the bituplins
    Jul 2008
    Ontario Canada
    76
    1
    I'm no expert, but what you're saying leads me to believe you have a bad battery and/or bad connection to the battery. You said the service engine soon (SES) light came on when the engine quit, but when you were able to restart it, the light went out. The SES light means the computer has stored a code, and normally the light won't go out on its own until 40 warm up cycles have completed and the problem hasn't reoccurred. However, you can clear the codes by disconnecting the battery and reconnecting it (not recommended normally), but this could explain why the light went out - your battery is giving an intermittent connection. This may also explain why your fuel gauge went a little whacky. Did everything else shut off too like your radio, etc.?
    Has the van been parked since May with the battery connected? Usually battery terminals corrode pretty quickly - disconnect them, and clean them thoroughly with a fine grit sandpaper or steel wool, and take a look around for any heavily corroded grounding wires under the hood and clean them up. That would be what I would look at first - always want to help a fellow GTA'er!
  5. #4
    Dec 2007
    9
    The light came out after it shut off, I had taken my battery to canadian Tire 3 weeks ago to check it up and they said it was good. sometimes it stall and the light come on and sometimes shut off and the light comes on, it stays on for a couple of days and then off again like nothing happen. I just need to find oput what is wrong I do not want to get stock in winter time with it. some body said it may be a tps has a fault conection, do you know where is this located it ? thanks for the info.!
  6. #5
    Jul 2008
    Ontario Canada
    76
    1
    What is the TPS? If it happens again, and the light stays on, I'd go directly to a mechanic to get them to scan the computer to tell you what code is showing up. It might be a computer malfunction - I have read of people having that problem on here. I would go under the hood, and look closely for every electrical connection I see and check for a good secure connection. Hopefully someone here has some input on this!
  7. #6
    Apr 2008
    338
    Hi might this be related to the gauge cluster-solder connection problem --that many vans encounter ?
  8. #7
    Apr 2007
    San Diego
    5,168
    Next time you see the service engine soon (SES) light come on try the key dance to get the fault code. What's the "key dance". Cycle the ignition key from off to on (not start) 3 times leaving it on. Count the flashes of the SES light. These flash combinations are the code we are looking for. All fault codes have two digits, each digit is separated by a pause, each code is separated by a longer pause. For example a code 21 would be flash, flash, pause, flash. Should finish with a code 55. This code can lead us to the fault.
    TPS = Throttle Position Sensor
    Tony0707 - I can't count out the CCD bus/solder joint issue but, in this cause I would lean toward a simple crankshaft sensor failure. Why? Usually with the bus issue you'll see multiple instruments fail and many times it won't crank. That's missing here...at least so far. At this point the fuel gauge issue is a ?
  9. #8
    Jun 2008
    387
    wow... didnt know that trick!... well i have no clue of a damm thing anyways.. thanks for the tip
  10. #9
    Jun 2008
    387
    Trick didnt work
  11. #10
    Apr 2007
    San Diego
    5,168
    So from off you went to on...off...on...off...on and never saw the service engine light?
    There's another way to read your codes. If the service engine light comes on and stays on try making your way to an Autozone or similar store. They will connect a scanner and read your codes for free. This will give you the more detailed "P" codes. They start with "P" and have 4 digits. Might try it even if the light is off.
  1. 1994 Grand Voyager SE 3.0L V6 Suddenly Failing To Start
    By JebusKrist in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 01-11-2010, 04:06 PM
  2. When RPMs drop suddenly, engine dies...
    By au9000 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 09-04-2009, 08:59 AM
  3. Steering - highway
    By lgret13 in forum 5th. Generation Chrysler Minivans: 2008-2016
    Last Post: 11-18-2008, 08:57 AM
  4. Soul Legend Issac Hayes Passes Suddenly
    By Glen Millar in forum The Fireplace
    Last Post: 08-10-2008, 09:56 PM
  5. 97 T&C Lxi engine dead suddenly
    By htx1997 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 09-05-2005, 01:53 PM
