Anyone deal with the Charcoal Canister or Purge Solenoid?
Results 1 to 10 of 14
Thread: Anyone deal with the Charcoal Canister or Purge Solenoid?
    Sep 2006
    517
    2
    My '01 is throwing a P0441 code (evap emission control system purge flow fault). I replaced the NLVD (natural vac leak detection assembly) and made sure that the gas cap was tight. I also scanned for damaged hoses underneath the van. Unless I missed something, that leaves the charcoal canister or the Purge Solenoid as the last components to inspect with this system. Anyone know where these are or how to inspect, or deal with this code?
    Here's a link that helped somewhat:
    http://www.obd-codes.com/forums/view...php?f=1&t=3716
    2014 Chrysler Town & Country 30th Anniversary Edition
    2014 Acura MDX
    1996 Mustang Cobra
    1995 Lincoln Mark VIII
    Jun 2007
    162
    How the system works
    NVLD
    I'm a retired ASE Master/L-1 Technician. I still keep current with the latest automotive technology. I now have over 400 repair articles, TSBs, and wiring diagrams on my blog: http://www.ricksfreeautorepairadvice.com//
    Feb 2007
    Southwest Ohio
    353
    BOB96:
    Do you hear the "whooosh" of pressure or vacuum when you remove the fuel cap??
    I just ended a long painful search for a cure to a P0442 on my Durango, and it was the fuel cap.
    $14 later to the stealer, and the tank goes whoosh when I remove the cap. No CE light!!!!!!!
    Don
    2011 Mineral Gray Hyundai Santa Fe GLS AWD 3.5L V6
    2014 Billet Silver Charger R/T AWD
    04 Flame Red 5.7L Durango SLT
    May 2006
    New Hampshire
    8,395
    Quote Originally Posted by n8ech View Post
    BOB96:
    Don
    While I have had cars that woosh when the cap is opened, neither of our DGC have ever done that even once since the day we rolled them off the showroom floor.
    2006 Acura TL 6-Speed
    Sep 2006
    517
    2
    Is there a way to check the gas cap? It doesn't seem like much could go wrong with it.
    2014 Acura MDX
    1996 Mustang Cobra
    Sep 2006
    517
    2
    Since I resolved my more pressing no heat issue on the '01 and replaced the oil sensor switch on the '05, I want to revisit this...
    It's not the gas cap, as I swapped the one on the '05 with the one on the '01 and had no change. Is there a way to use a multimeter to check the purge solenoid? Anyone know the location or have a picture? I'm trying to avoid my old methodology of just swapping parts (I've replaced the NLVD, starter, thermostat, and radiator cap from various failed diagnosis).
    2014 Acura MDX
    1996 Mustang Cobra
    Nov 2008
    DeSoto County, MS
    2,926
    Quote Originally Posted by BlackOnBlackCobra96 View Post
    I replaced one on a friends 03 T&C but for the life of me I couldn't remember where it was. I believe it was under the hood on the left side(passenger side)...close to the radiator.Try following vacuum lines according to the vacuum line diagram and see if you can find it.
    Sep 2008
    Canada
    405
    The purge solenoid is normally closed unless actuated.
    Remove it and see if you can suck or blow through it, if you can replace it.
    If any of the hoses to the fuel tank or charcoal canister are pinched or blocked it can also cause this fault.
    2003 GRAND CARAVAN SPORT
    1997 RAM 1500 SPORT 4x4
    2003 ALERO
    Sep 2006
    517
    2
    Quote Originally Posted by rabbler View Post
    Do you know where the part is?
    2014 Acura MDX
    1996 Mustang Cobra
    Nov 2008
    DeSoto County, MS
    2,926
    It should be listed on the vacuum line diagram sticker that is under your hood.
  1. Emissions Duty Cycle Purge Control Valve
    By ikemando in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 01-22-2009, 10:09 PM
  2. No Power - Evap Canister Purge Solenoid
    By chengny in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 11-23-2008, 02:36 AM
  3. Hello- can the canister hose leak be fixed by myself
    By qqxue in forum Introduce Yourself and Your Minivan
    Last Post: 03-13-2008, 02:54 PM
  4. Emmisions: Evap canister and hose....
    By theboneskes in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-20-2007, 12:47 PM
  5. Europe charcoal air filter
    By Miguel in forum Items Wanted
    Last Post: 09-18-2006, 07:02 PM
